0 Members and 1 Guest are viewing this topic. Read 10190 times.
The 4.5" are really working out and they are way better than I anticipated. I have fuller bass and the transparency of the 8"s. Scale is a bit smaller than the larger speakers, but it's all there. I don't know about an alnico version of the 4.5" driver yet, but I did get the latest plot on the 8" alnico and it's really good. Very well balanced and smooth in the mids with bit more bass energy. I hope to get the drivers to test. One drawback is they are about 93dB spl.
I have figured out the Hemp revolution and the OBs finally out and will be getting the proto types drivers after the New Year. The drivers are going to be 16 ohm only. The OB is a 1.5 way in parallel and will end up as 8 ohm.
Quote from: Louis O on 23 Dec 2006, 10:41 pmI have figured out the Hemp revolution and the OBs finally out and will be getting the proto types drivers after the New Year. The drivers are going to be 16 ohm only. The OB is a 1.5 way in parallel and will end up as 8 ohm. Louis,Do you or Vinnie have any predictions as to how the Signature RWA amps are going to deal with a 16-ohm load? Are those of us with B-200 based speakers going to need to look into autoformers for our amps that don't have 16 ohm drive capability?Thanks,Jim
The RWA Signature amps will have no problem with a 16-ohm load. However, the max output power into such a load will be approx reduced in half. No a big deal with a high efficiency driver. Most likely, you'll need to turn up the volume a little more to get the same sound level out of it. Of course if the driver is more efficient than the B200, that would counter this need somewhat.
