Promitheus TVC passive preamp anyone?
0 Members and 3 Guests are viewing this topic. Read 607531 times.
guest1632
  • Guest
Re: Promitheus TVC passive preamp anyone?
« Reply #780 on: 18 Jan 2007, 08:28 pm »
GHM,
Can't believe 777 replies 24663 hits on this subject.Can't believe the interest,maybe other Manf's will offer performance and VALUE like Promitheus.ARE YOU LISTENING MANF's.
     So thanks again for bringing the TVC to AC.
rollo
Hey all,
Just got some email from Nicholas. He's now mounting the switches directly to the front panel. He says it sounds better and doesn't know why. I emailed him with the question as to how was that done. How much of the shaft of the switch did he have to take off?
I'll keep you in tune as soon as I know anything else.
Ray
guest1632
  • Guest
« Reply #781 on: 18 Jan 2007, 08:33 pm »
GHM,
rollo
Hey all,
Ray
Well, the actual quote from his email is:
"I found a better idea in the future, I will be directly mounting the switches to the chassis next time. Some how the sound is better
Don’t know why though"
So I assume it's on standoffs? and not mounted to the front panel? Or is it the other way around.
Ray
xsb7244
« Reply #782 on: 19 Jan 2007, 02:40 am »
besides GHM, has anybody bought a power energizer?  would like your comment and is this a must have item?
smk5r
« Reply #783 on: 19 Jan 2007, 04:06 am »
I have a power energizer and find it a welcomed, if not indispensable, addition.  Bass is more tuneful, tighter, punchier and treble seems smoother without loss of extension.  The PE is truly remarkable--I liken it to having a dedicated 20 amp circuit for a tenth of the cost.  I will post more later time permitting.
analogmart
« Reply #784 on: 19 Jan 2007, 06:26 am »
Hi Rollo thanks my friend. Yeah I can't believe the hits and replies either!!  :o I hope other manufactures get on the boat and offer such great performance for the price. I've been searching the net for companies like Promitheus Audio. There are a few out there..you just have to look really hard for them. :D
good to check.
www.sacthailand.com
www.magnetaudio.com/store/en/shop.asp
www.siliconthai.com/index_thai-1.htm
 :thumb:
NewBuyer
« Reply #785 on: 19 Jan 2007, 08:12 am »
I have a power energizer and find it a welcomed, if not indispensable, addition.  Bass is more tuneful, tighter, punchier and treble seems smoother without loss of extension.  The PE is truly remarkable--I liken it to having a dedicated 20 amp circuit for a tenth of the cost...
How are you using your Power Energizer - is it plugged into a power strip, or are components plugged directly into the PE, or is the PE plugged into a wall socket all by itself, etc? :?:
smk5r
« Reply #786 on: 19 Jan 2007, 12:57 pm »
I've tried various configurations and found plugging the Power Energizer directly into my power conditioner along side other components provided for the most expansive soundstage I've experienced to date with the benefits I mentioned previously.  Another aspect I neglected to mention, which was true of all of the various configurations, was the utter silence the Power Energizer 'introduces.'  All background noise/hiss disappears.  I have to turn the volume on my tube preamp I all the way up (about 5 o'clock, where 6 o'clock is no sound and most music is played at 9-10 o'clock) to hear anything.  Music also seems louder and more natural, more live.
guest1632
  • Guest
« Reply #787 on: 19 Jan 2007, 02:54 pm »
good to check.
www.sacthailand.com
 :thumb:
Hi Analogmart,
You forgot:
http://www.diyhifi.org/amplifierguru/guru_001.htm
All of the reviews I have read for the most part have been positive.
Ray
Early B.
« Reply #788 on: 19 Jan 2007, 05:39 pm »
Been listening to my new TVC for the past couple of days in utter amazement. The sound has exceeded my expectations. Tremendous tonality, detail, and realism. This is my best audio purchase, to date.
I'm speechless. There's nothing more to say...
rollo
  • Rollo Audio Consulting -
« Reply #789 on: 19 Jan 2007, 06:24 pm »
[ote]
Early B,
             The best is yet to come,good to hear its going on for you.Burn in with Volume control set 2 or 3 clicks back from full gain.
              Which version to you buy?The best part of the presentation to me is the natural way it handles sibilance of the human voice,not exaggerated,hyped up or artificial.
HAPPY LISTENING AND GOOD LUCK        rollo
Dan155
« Reply #790 on: 19 Jan 2007, 09:38 pm »
Ray
I've built the GB150.  It's a superb amplifier.
Whitese
« Reply #791 on: 19 Jan 2007, 09:53 pm »
I am pumped now..my TVC Ref w/ebony left supposedly on wed to me in GA...whats the approx travel time?
I sold my Jeff Korneff 6SN7/54 tubed pre...I hope the Bel Cento SET's get along with the TVC..
guest1632
  • Guest
« Reply #792 on: 19 Jan 2007, 10:29 pm »
Ray
You're absolutely right! The one review I read, there was some possible issues with the power supply. Other than that one review, this is why I too want to build the 300D amp.
Ray
wendell
« Reply #793 on: 19 Jan 2007, 10:48 pm »
I've got the GB150 and 300D kit for almost 7 months now and have not yet finished yet,  I sent the GB150 that I started to a friend to tap out the heatsinks and chassis its going on but he's been so busy that I haven't gotten it back yet :x   I should give him a call and see whats going on.  I probably would have been better for me to get a press and tap kit and do it myself :duh:
guest1632
  • Guest
« Reply #794 on: 19 Jan 2007, 10:59 pm »
Hi Wendell,
Give me a couple of months, and if you haven't started your 300 yet, would like to buy it from you. You bought it with the stuffed boards?
Ray
Zero
« Reply #795 on: 19 Jan 2007, 11:45 pm »
My apologies if it has been asked previously in this 70 page thread....   but has anyone tried the hybrid amps?
guest1632
  • Guest
« Reply #796 on: 19 Jan 2007, 11:52 pm »
Hi, I don't remember either. But I figure no issues. If you buy one, and it doesn't work for you, trust me, it would be snapped up in an instant.
Ray
Early B.
« Reply #797 on: 20 Jan 2007, 04:53 am »
Just curious --
When I opened the TVC, I noticed the copper wires are tie wrapped. Can someone explain why the performance of the TVC is not affected by all of the wires touching each other?
Thanks.
guest1632
  • Guest
« Reply #798 on: 20 Jan 2007, 05:17 am »
Just curious --
Thanks.
Good question. I would think if they weren't the inside of the case would be a mess.
Ray
tanchiro58
« Reply #799 on: 20 Jan 2007, 05:39 am »
Just curious --
Thanks.
Hi,
I thought that way too after opening up my TVC. Then I think of a layman's thought that because it is a passive preamp (no electricity goes through). So it is a matter of signal going through like a magnetic field. Therefore, you do not worry about why?
