0 Members and 1 Guest are viewing this topic. Read 11937 times.
I am not a DIY and would not even try to attach fabric to say a gik panel. Thanks all for suggestions
> Id like to try some wall treatment which wont get me divorced. <This comes up often, and here's my take: The real problem with acoustic panels is not so much whether they're white or purple, or have plain or fancy fabric on them. The real issue is they are large and you need a bunch of them to truly tame a room. The good news is more and more people are using dedicated rooms where the look of a bunch of panels and traps is not a problem. But what I never understood is why the appearance of 6 foot tall towers speakers, plus a rack full of gear, plus a pair of monoblock toob amps on pedestals with cable elevators holding up garden hose size wire is okay, but acoustic panels are not okay. --Ethan
But it isn't just WAF, it's MY AF as well. I want to relax and enjoy my room... not look at a bunch of ugly unfinished junk on the walls.
I wish someone made a bass trap that looked like a totem pole or something like that...
... But some of the posts I read gave me a bad impression of the burlap and I was running around trying to find alternatives...
