Acoustic Treatment-Wall Panels As Artwork
0 Members and 1 Guest are viewing this topic. Read 11938 times.
bpape
    • Sensible Sound Solutions
Re: Acoustic Treatment-Wall Panels As Artwork
« Reply #40 on: 17 Sep 2006, 06:23 pm »
There isn't batting as such - but there is another layer of material (can't be too specific - sorry) between the external cloth and the mineral wool.    In the case of the GIK's, if there was batting involved and exposed to the outside, it would increase the upper mid/high frequency absorbtion of the panels.
Bryan
BradJudy
« Reply #41 on: 18 Sep 2006, 02:20 am »
Does this extra layer reduce the amount of shedding?
bpape
« Reply #42 on: 18 Sep 2006, 02:30 am »
Yes.
fajimr
« Reply #43 on: 19 Sep 2006, 12:45 pm »
Please post pics, I know I'd be interested in seeing how your turned out.  That design sounds like something I was thinking of trying myself.
o.k. if I did this right, here they are:
http://www.audiocircle.com/index.php?action=gallery;area=browse;user=3223
good luck and ask any questions you have!
rajacat
  • Washington State
« Reply #44 on: 19 Sep 2006, 03:31 pm »
Here is a source for cotton insulation in bulk.
http://www.soundprooffoam.com/quiet-batt-insulation.html
This would solve the shedding problem completely and be much more pleasant to work with.
Raja
bpape
« Reply #45 on: 19 Sep 2006, 03:43 pm »
If you're interested in cotton based products, PM me.  I have a source for quite a bit at more reasonable prices.
Bryan
sabes
« Reply #46 on: 9 Nov 2006, 09:59 pm »
I am trying address a highly sibilant room with lots of windows-which also doubles as a living room, play room and dining room here in NYC. (ahaaa the pleasures of Manhattan inches). Id like to try some wall treatment which wont get me divorced. In searching, I recently have come across two firms out of the UK who are doing wall panels with an artistic bent-exaclty what i would like to do. they are:
http://decorative-art-services.co.uk/Art%20Acoustics/Welcome.html
http://acousticartpanels.com/
kbuzz: did you ever pursue the acoustic art panel route? cost? effectiveness?
The first ooks particularly compelling, I am not sure or pricing but shipping to the states will probably be cost prohibitive.  Does anyone know  if anyone is offering a similar arty acoustic panel here in the states.  I am not a DIY and would not even try to attach fabric to say a gik panel.  Thanks all for suggestions
bpape
« Reply #47 on: 10 Nov 2006, 12:13 am »
http://www.acousticalsurfaces.com/fabric_panel/graphic_walls.htm
I can get these but they're very expensive.  The only way they're even remotely affordable is if you buy several of the same print.  Each print has a $100 setup fee in addition to the cost of the panel itself.
Bryan
