0 Members and 1 Guest are viewing this topic. Read 43829 times.
Sounds like you've got a good plan going Mike. I hope it turns out well. Perhaps I'll even get to see/hear it.
Thanks for being an early US pioneer on one of these amps, Mike. Please keep us posted.
Hi KLe,I answered you in the other forum you posted to, but will copy here for general interest.1. The amplifier is complementary throughout. The input differentials are complementary BJT, the driver stage is complementary Class A 250MHz BJT, and the output stage is complementary common source MOSFET. Even the input stage current sources and thermal comp are complementary. Sexy, hey?2. The input BJT pairs are matched to 5% on current gain to minimise DC offset particularly in DC couple mode. 3. The output MOSFETs are matched in a custom jig to 10mV on Vgs on to facilitate equal sharing of load current in conjunction with their internal resistance. 4. The amplifiers are designed to function on nominal 4-8 ohm loads and are Vgs limited to limit maximum currents in untoward situations. 5. The amplifier has been optimised for low bias Class AB operation with residual distortions well contained below 0.005% and inaudible at normal levels, but can be biassed up to Class A operation of 1/3 the power rating on suitable lower continuous duty supplies for those who need it. I have not experienced any audible benefit. 6. The topology with the power efficient common source output stage can swing to within 2V of the supply rails so, in conjunction with the high PSRR of the design , can perform with lower supply voltages and capacitance for a given power output over conventional designs. The difference is typically 30% - making this a very lean, green performer. 7. 250VA for the GB300D is about the minimum I would suggest for full output on one channel, typically 300VA. If the power output is reduced this could be reduced further without detriment. Hope that helps. Cheers, Greg
