0 Members and 1 Guest are viewing this topic. Read 75048 times.
The technical issues intrigue me as I am a bit curious about the details of true CD performance being possible from such a shallow device. Then again, depending on radiation angle (dispersion), this may very well be possible. Undoubtedly it is as Brian would not stake his reputation on "snake oil." Still, I'm curious...but then I usually am. -Bob
IMHO, though, CD without pattern control is only half the game. Without a very large room or extensive room treatments, launching that much energy in all directions will bring the room into play pretty significantly - precicely what conventional waveguides are aiming to avoid.
The second element of the design is also plainly visible, but easily overlooked: The flat face of the device. This flat face operates as a 180 degree waveguide down to the frequency where the baffle is 1/2 wavelength wide. In fact speaker baffles can be considered to be 180 degree waveguides, but usually the drivers mounted on them beam enough that the baffles only function as waveguides over relatively small portions of the spectrum.
RM40's of any vintage can take the upgrade. In addition to the waveguides new lower Q PR's are required as the system sounds too bassy without them.
I'd think something like this can mount the way our grill cloth does.
The patent also discloses a differently configured waveguide for cone dynamic/dome tweeter systems.
So with this change, what does someone off center perceive?
