Speaker Cable poll...list your Giant Killer recommendations
0 Members and 1 Guest are viewing this topic. Read 27869 times.
carusoracer
Speaker Cable poll...list your Giant Killer recommendations :)
I need a fairly long run on one side..so of course that means I need to have equal length cables Approx 15ft or 4 meters total per side. With that statement made as you can tell this changes the pricepoint on many cables and their affordablility. Any recommendations or favorites that you may have heard? I'm looking toward Analysis PLus Oval 9..but a litte pricey
 Always great to hear from forum members...Listening tastes:Jazz,New Age,Bossa Nova,Classical.
Current Speaker cables PS Audio xtreme Prelude..nice soundstage,good layering,somewhat relaxed highs. They are midrange shy which is what I'm trying to improve and produce some seemingless high end. I do like the warmth that they provide with some emotion and nice extending bass.
Rig: Musical Fidelity A3cr /Signal Cable PC
       EE MiniMax(NOS Tubes)/Herbies Halo's
       Music Hall Maverick/VH Flv 4 PC/VH Pulsar IC
       Gallo Acoustics Reference 3/PS Audio prelude cables
       Cryoed Hubble Outlet/Silclear/Walker Vivid
Looking forward to replies..Have fun :P NO slamming please
Kevin P
    • http://www.diycable.com
« Reply #1 on: 21 Jul 2005, 04:26 pm »
Canare 4S11    Cost just over a buck a foot.
If you have money to spend the twisted pair via John Risch design with Cardas SE-15 is a good choice.   Cost multiples of the Canare though.  :-)
Gordy
« Reply #2 on: 21 Jul 2005, 04:55 pm »
Chris VenHaus's 12awg cryo'd twisted pairs @ $2.99/ft. is excellent, you'll need to terminate the wire with something like Vampire's HDS5 copper spades though...
http://www.venhaus1.com/VH_Audio_Test.html
ScottMayo
« Reply #3 on: 21 Jul 2005, 05:24 pm »
For a fancy set up, I like milspec hookup wire - the 8ga stuff with silver coated strands, available for about 1.60$/ft (Caveat: you need 2 runs of it for a speaker! so it's not the cheap way to go). The silver probably doesn't reduce resistance significantly (and with 8ga wire, it wouldn't matter much if it did), but silver's nice for making bare wire connections, because oxidation isn't so much of a concern. Caveat: it's stiff, but it's very sturdy.
Belden 5T00UP is only 0.57/ft, you only need one cable per speaker, and I doubt any one, no matter how golden ear'd, could pick it out from any other decently clean copper or silver pathway, no matter how exotic, in an A/B/X test. Large hungry speakers might want something heavier gauge. But at that price, it's worth getting some and seeing if it will do.
Jumper cable (yeah, the stuff they make car battery jumper kits out of) makes an interesting statement, if your speaker can handle fat wire. It's hard to argue that any speaker in any rig is going to demand more current than that can deliver. 6ga is ~ 1$/ft - again, you need 2. You can get fatter versions, but check your connectors first.
Thebiker
Cable Recommendation
« Reply #4 on: 21 Jul 2005, 05:51 pm »
Go take a look at this website.  http://www.cobaltcable.com
I have been using their speaker cable for well over a year and am totally pleased, with the sound quality, the product quality and the prompt and pleasant service that I have received.
I am doing (out of necessity) a 5 meter run from a Manley Stingray to a pair of JM Lab 816s.
Thebiker
« Reply #5 on: 21 Jul 2005, 05:51 pm »
Don't you love technology.  I get a "System Timed Out" error and it sends anyway :?
Carlman
« Reply #6 on: 21 Jul 2005, 07:56 pm »
I've had good success with Tara Labs Phase 2 w/ TFA return.  You can get it at Fatwyre.com at $100 for a 10' pair... probably not much more for 15.
-Carl
GerryD
« Reply #7 on: 21 Jul 2005, 08:43 pm »
River Cable Flexygy 6 works well in longer lengths.
www.rivercable.com
dave_c
« Reply #8 on: 21 Jul 2005, 09:00 pm »
I really liked the Analysis Plus Oval 9's.  I was only able to compare them to the AP Oval 12's which are also nice.  The Oval 9's are much better though, deeper bass and better balance.   I think they are worth the money.
tommytube
Deep cryogenically treated 12 AWG magnet wire
« Reply #9 on: 21 Jul 2005, 09:30 pm »
I built some of these yesterday to try in my secondary rig and they outright rocked.  For .50 cents a foot, hard to beat price wise.  Good extension, slightly warm, good tonality....  I'll try it in the big rig soon.....
http://www.cryo-parts.com/bulkwire.html
I typically use Cardas SE11 which is also a great budget cable for those who can't afford the Golden Ref stuff.
Grover
« Reply #10 on: 21 Jul 2005, 10:24 pm »
I just replaced my Analysis Plus Oval 9 with some Luminous Audio Technology Renaissance cables.  I think the bass is as deep but the highs are much more airy and detailed.  The Renaissance is more expensive than some of the other options given to you above.  But I think it's about half what the Oval 9 costs retail.  The LAT Rens are $25.00 per stereo foot plus $40 termination.
jermmd
« Reply #11 on: 22 Jul 2005, 02:20 am »
This is "Page 2 of 1." :o
Where are the missing posts. I think I'm in the Twilight Zone.
Joe M.
jermmd
« Reply #12 on: 22 Jul 2005, 02:31 am »
Everything seems to be working now except I don't see an earlier post of mine.  I bought a pair of Xindak speaker cables here recently. I'm not so sure about sonic differences between cables but these are well built, quality cables and I like the "ribbon" design.  By the way, check out NY Sound's new website.
Gordy
« Reply #13 on: 22 Jul 2005, 03:09 am »
Quote from: Carlman
-Carl
Hi Carl!
I read a while back that Fat Wyre/The Cable Co. was down to they're last 15 ft. or so of the Phase 2 and they had the world supply...  I have not actually called to confirm that.
Gordy
bubba966
« Reply #14 on: 22 Jul 2005, 06:36 am »
I'm using Bolder Cables M-80 speaker cables. http://www.boldercables.com/Store.asp?m=TheBolderCableCompany&n=10&k=109874&s=Audio+Cables
Here's a pic.
I think that's actually my center channel cable if I'm remembering right. It's not my pic...
They're great cables. I'd want to upgrade my speakers to the next better model from the same company before I got the M-80's. The M-80's made such a huge improvement that I no longer feel the desire to upgrade my L/C/R speakers.
grub
« Reply #15 on: 22 Jul 2005, 07:23 am »
Gregg Straley's stuff is great for the money.
-->grub
mcgsxr
« Reply #16 on: 22 Jul 2005, 10:20 am »
2nd vote for the Bolder M-80.
nickspicks
« Reply #17 on: 22 Jul 2005, 11:16 am »
Quote from: grub
-->grub
i've run a bunch of GS's cables...and they are, hands down, the BEST cables i've ever heard.
if anyone wants to get in touch w/him.  i've got his email addie.
carusoracer
Giant Killer recommendations Speaker Cables
« Reply #18 on: 22 Jul 2005, 01:06 pm »
Thanks all for the replies....There are several companies and products that I'm not familiar with. It is nice to hear from others and their trials and tribulations.
I think I'm heading toward "Stereo Hell". I'm constantly trying to think of ways to enhance my listening experience :lol:
I did edit my post. The run is 3 to 4 meters on one side, thereby totaling approximately 8 Meters :cry:
CornellAlum
« Reply #19 on: 22 Jul 2005, 01:28 pm »
d vote for Bolder M-80, though I run mostly Bolder Nitro wire these days.
