Audio/Video Gear and Systems
Owner's Circles
VMPS Speakers
RSorak
Foam for wave guide?
0 Members and 1 Guest are viewing this topic. Read 1711 times.
Campindog
24 Sep 2023, 07:17 pm »
The foam inside my RM30's wave guide is done and melting away. This is for the original slotted grills. Does anyone know where Brian sourced this? Was it tape or glued in place? Any alternitives?
Derek
Doublej
Re: Foam for wave guide?
24 Sep 2023, 10:53 pm »
No Rez is a possible substitute. I would contact GR Research and ask them.
https://gr-research.com/product/no-rez-24x27-4-pack/
GeorgeAb
Reply #2 on:
26 Sep 2023, 04:19 pm »
Here is a post on wave guide which includes drawing diagram and recommended material.
https://www.audiocircle.com/index.php?topic=176018.0
From post: "Material recommended was Bulk Fine Foam Filter 60 PPI 12x16x3/8in Uni BF-4."
Looks like it is availble here:
https://www.amazon.com/FOAM-FILTER-SHEET-BLACK-Manufacturer/dp/B008Y2H73E
Bob Stark
Reply #3 on:
26 Sep 2023, 10:41 pm »
Hey Derek,
Use a good spray on adhesive after cutting to size. Spray on the foam and carefully press in in the correct place.
Bob
Campindog
Reply #4 on:
2 Oct 2023, 04:08 am »
Got it. Thanks to all 3 replies.
Owner's Circles
VMPS Speakers
RSorak
