0 Members and 1 Guest are viewing this topic. Read 20804 times.
eric that is one of the wierdest & more disturbing avatars. is that guy or thing crying, or swatting flies or looking for a fight or.....?
What Alons are you getting?
Eric,What are you going to use to power your alons?
Quote from: Phil PEric,What are you going to use to power your alons?At first the TacT RCS 2.2X with S2150 amps. That is my current setup. I'm looking into some possibilities with the Atma-Sphere MA-2 MKII.3 and BOZ 216/2200 also.
Quote from: ekovalskyQuote from: Phil PEric,What are you going to use to power your alons?At first the TacT RCS 2.2X with S2150 amps. That is my current setup. I'm looking into some possibilities with the Atma-Sphere MA-2 MKII.3 and BOZ 216/2200 also.I have owned Atma-Sphere M60's and those suckers literally raised the temp in the room a good 10 degrees easily. The M60's had 12 tubes in each amp while the MA-2's have 26!!!Might not be the best choice for a desert dweller. George
They were expensive, unbeleiveably huge, ran hot, & blown up more often than running.
