Painting Speaker Cabs
0 Members and 1 Guest are viewing this topic. Read 9188 times.
Peter J
  • Hmmmm
Re: Painting Speaker Cabs
« Reply #60 on: 6 Dec 2022, 10:48 pm »
I highly recommend a gun. Even the $25 spray guns at harbor freight do a really good job. Take your paint and add water to it until it's a thinner consistency. Then spray with the gun and you will have a MUCH better outcome. Trust me!
I doubt RMarshall would have been happy with results of that recommendation. I'm guessing the Cover Stain was the oil-based variant and most urethane is also oil-based. Water where you should be using mineral spirits is never good. And just so you know, most water-based paint recommends maximum of 10% reduction. Some say not to reduce at all.
