Painting Speaker Cabs
0 Members and 1 Guest are viewing this topic. Read 9079 times.
RMarshall
  • Roger
Re: Painting Speaker Cabs
« Reply #40 on: 31 Aug 2022, 01:31 am »
I'm sure you all have heard the saying "better to be lucky than good." That pretty much nails how my speaker cab painting went.
I had used Knisser Cover Stain as a sealer. I was very happy with how that came out. 3 coats with a bunch of sanding. It's white so I figured my top coat in a midnight blue, would take 2-3 coats to cover. I used a Sherwin Williams Emerald Urethane as my paint. Applied it with a micro fiber roller.
After one coat, I couldn't believe what I was seeing. My wife took one look and forbid me to do another coat. This was completely unintended.
Sorry for the double pic.
« Reply #41 on: 31 Aug 2022, 02:09 am »
Are you not going paint inside?
RMarshall
  • Roger
« Reply #42 on: 31 Aug 2022, 02:18 am »
Not sure if you're joking or not, but no. I've started the No Rez process.
« Reply #43 on: 31 Aug 2022, 02:29 am »
The inside paint affects the sound, the exterior finish are unimportant to the sound.
https://www.audiocircle.com/index.php?topic=100689.0
RMarshall
  • Roger
« Reply #44 on: 31 Aug 2022, 03:04 am »
Interesting, but I'm lining the interior with No Rez. That will have to do.
sandbagger
« Reply #45 on: 31 Aug 2022, 03:34 am »
Love it, no really really love it
not a fan of just black boxes, or in the GR Circle I should say black baffles :P
« Reply #46 on: 31 Aug 2022, 03:41 am »
Painting is absolutely not needed on the inside of the speakers.  The NoRez is more than enough.
RMarshall
  • Roger
« Reply #47 on: 31 Aug 2022, 03:51 am »
The paint in the tray on the left is the color I was originally going for. I was visualizing a deep blue cabinet.
One more just because.
Appreciate the comments.
« Reply #48 on: 31 Aug 2022, 03:52 am »
The internal treatment will shape the sound greatly, one have to do the internal treatment according his personal taste listening the various options, aside painting inside will prevent humidity/mould along the winters.
EDITED
mkane
« Reply #49 on: 3 Sep 2022, 01:01 am »
Nice Job.
Danny Richie
« Reply #50 on: 7 Sep 2022, 09:09 pm »
Wow, nice paint job.
RMarshall
  • Roger
« Reply #51 on: 8 Sep 2022, 11:21 pm »
Thanks Danny. Yeah, I'm pretty happy with them.
HappyGene
« Reply #52 on: 20 Nov 2022, 12:03 am »
No problem - I got to look at it twice :)
Craig Young
« Reply #53 on: 2 Dec 2022, 03:22 pm »
I am planning on getting speakers and subs in the near future from gr research and I plan on painting the MDF. I am thinking of using either valspar bonding primer or rust oleum filler primer. Final color is to be determined. I like the idea of using spray paint.
nlitworld
« Reply #54 on: 2 Dec 2022, 03:41 pm »
I would highly advise against rust-o-leum unless you choose to use their material all the way through. Super chemically reactive. When you get ready to paint your speakers, just send me a message and I'll walk you through the whole process using correct materials.
Spitfirejack
« Reply #55 on: 2 Dec 2022, 07:25 pm »
I used the cabinet paint before and it's really nice stuff. I used a wood filler on the wood first though because I like a smoother finish. Love that color.
Craig Young
« Reply #56 on: 2 Dec 2022, 11:09 pm »
Thanks I could use your help in pointing me in the right direction. I love your blue NX-Studio speakers, I am thinking of getting that model as well.
Peter J
  • Hmmmm
« Reply #57 on: 3 Dec 2022, 03:03 am »
Welcome to the forum, Spitfire. For clarity, are you referring to the Sherwin-Williams urethane mentioned by RMarshall? When you say "wood filler" is it possible you mean grain filler or perhaps polyester filler? RMarshall's cabinets look pretty smooth from here.
RMarshall
  • Roger
« Reply #58 on: 4 Dec 2022, 03:15 pm »
If you get the flat packs, or have them pre-built as I did, from GRR, the quality of the MDF is very good. No need for wood filler. A good sealer and a ton of sanding will get you there.
Badd99
« Reply #59 on: 6 Dec 2022, 09:07 pm »
You and I are thinking a lot alike.
My cabs arrive this Wednesday. Should have the paint by the 20th. With my work schedule, it will probably take a couple weeks to get the cabs properly sealed and sanded.
Bought a brush recommended to me, and trying that route.
Ready to get started.
Roger
I highly recommend a gun. Even the $25 spray guns at harbor freight do a really good job. Take your paint and add water to it until it's a thinner consistency. Then spray with the gun and you will have a MUCH better outcome. Trust me!
