0 Members and 1 Guest are viewing this topic. Read 139528 times.
pat@warI'm surprised at such a response, and a bit disappointed. I don't know why you would seek to personalise this debate. I am not going to comment on my identity, whether I know you or your shop, or my other contacts - that's why we have nicknames isn't it? - but I would ask you not to go making the sorts of assumptions you have in your post. And assumptions are all they are! That said, I have no way of commenting on your findings re the NFs and who thought what, front ends etc. ...
....fell down when the sound became denser and as I mentioned before, were simply weak with hard rock, actually quite unpleasant and glarey at volume.
...I postulated previously, are you falling into the trap of regurgitating learned response?
can you really hear a damping factor of 4K?
I appreciate your response, Jason (or whoever posted from NuForce) and I applaud your balanced, professional stance. Yours is the sort of response I respect, because you are not hog-tied by your emotions or hostage to ego or self-esteem. You have - very honestly and I would say generously, given your position as a company insider - acknowledged the possible HF shortcomings with the current NuForce amps that I mentioned, and rightly pointed out that the accolades NuForce has been receiving are not just fro ...
I would question that your amp may not have been broken in? they go from sounding okay, to sounding terrible to sounding better and then finally awesome.
How long does a pair take to completely break in?
AC Grounding and Pre-amp compatibility problem update:Brief problem background:Some homes (especially in Europe) have no AC ground and that create loud white noise (huming, hissing). Even if it has AC ground, but in Europe with those two pins plug, there is no standard which pin is referenced to ground (flip the plug and see if the noise goes away)Some pre-amps connect its signal and chassis ground together (not suppose to do that) and also create loud noise for NuForce.If you're one of ...
HELP!! Nuforce amp wiring problem.Gentle People, After receiving my REF 8 Amps, I found that the two were wired differently! On one of the amps, the ground on the RCA input jack was sandwiched between the chassis and the plastic washer, effectively grounding the input to the chassis. on the other amp, the ground was floated from the chassis with the plastic washer between it and the chassis.My question is which way is correct? Kerry
