Question for John :Can you do the measurements, apply driver response correction, and add the crossover without inserting any of the time domain / phase correction? Rick
The notch filter usually used with the Excel drivers is necessary with analog crossovers of low slope to prevent ringing, since even low level signal at the problem frequency is problematic. Since the DEQX can implement an effective "brick wall" filter below the problem frequency, there is no output at the problem frequency and no notch filter is needed. For drivers that have uncontrolled response within their usable range (for instance some of the B&G planars) the DEQX will reduce output at the appro ...
DSK, if the drivers have good dispersion and low cone distortion, they will blend as though there is no difference. That's why it's important, in general, to use very rigid drivers that don't have harmonic distortion in their useful bandwidth.
Couple Qs about the DEQX:1) Can you use it full range, without the xo features, say while you are mucking around, or to compare the xo features to standard implementation?2) Does DEQX have any way to correct for impedance curves? Presumeably to gain the best implementation of a speaker design one should try to obtain a relatively flat impedance response of the drivers, via Zoble traditionally. I know you can man-handle the ultimate FR which somewhat alleviates the need for a zobel, but I can't help ...
...What a difference! The SS was certainly a nice tweeter, but these ribbons are much more to my liking. The horizontal dispersion is extremely flat over a far wider angular range, and the effect on the stereo image is nothing short of remarkable. ...
Jim, just did a quick search around on these LCY ribbons. From what I read, they have far better VERTICAL dispersion than typical ribbons, but there is little written on their HORIZONTAL dispersion. I saw one comment that suggested they are not as good as typical ribbons in this regard.Did you definitely mean that HORIONTAL dispersion is wider?
Yes, I do mean that the horizontal dispersion is much better than my ScanSpeaks. The LCYs are notable in that their vertical and horizontal dispersion characteristics are both quite good - unlike some ribbons. Here (http://www.e-speakers.com/products/lcy-components.html) is a link illustrating the off-axis performance of the LCY-110 (similar to 130 in this regard). As you can see, 30 degrees off horizontal is virtually identical to the on-axis response. And, 30 degrees of vertical is only dow ...
Rick - Per your suggestion on Madisound, I ordered a Solen 50 uF cap for use in this application. I had it all wired up on a protoboard for use. But, after a discussion with Andre at e-Speakers, I was convinced that I would never saturate the LCY's transformer with the small offsets I am seeing out of my amp (~3 mV DC). So, I am currently running these tweeters without the cap. The only problem I ran into during setup with the DEQX was that I neglected to bump the start frequency of the log sine ...
Rick - I think that the public DEQX users group is useless. However, the private DeqxBeta is very helpful. While there are only ~130 registered users on that forum, but many are quite knowledgable and helpful. When I received the unit, I read all (~900) posts and it really helped me become familiar with the unit. It also made me happy that I had not purchased one earlier, since there were a number of bugs that were resolved by other innocent victims prior to my initial use. If I want buggy software ...
Phil - I certainly agree that much of the "fun factor" for most audiophiles is mixing and matching components. Personally, I think that iterating through different amplifiers, CD players and other electronics and particularly cables is a waste of time. The specifications on any reasonable modern gear is virtually perfect, compared to the inaccuracies introduced by speakers and the interactions of the listening room. So, how about developing a speaker system that is much more modular? I mean, who ...
