0 Members and 1 Guest are viewing this topic. Read 85329 times.
Uh huh. Seriously though, DEQX automatically corrects for things such as making sure the drivers sum properly and does it effortlessly. It removes or avoids issues that usually require compensation networks or notch filters and you can run lower crossover points which means far better dispersion. Using capacitors, resistors or inductors to do this is like using an abacus instead of a computer. I'm all ears wanting to know what DEQX can't do in this regard.
That's why you can't just expect to whip out a DEQX-based system any more than a passive system. It's faster, perhaps, but then, again, DEQX leaves you with just the sound of the drivers/cabinet, so the next thing you know, you're doing a total overhaul on those too.My main point is that I can't think of an instance where inserting passive components into the signal path would help DEQX do it's job better or make the final result better. I've worked with a lot of customers on DEQX and handled prob ...
.... It removes or avoids issues that usually require compensation networks or notch filters and you can run lower crossover points which means far better dispersion....
2-way + 2 subs = 3-way
Either way, works fine. The ideal driver complement (generally) would be:1" + 4" + 8"1" + 5" + 10"1" + 6" + 12"The 1st doesn't have a ton of advangages, the 3rd one gives you the best bass extension and output, but the 2nd gives you the best combination clarity, dispersion, integration, which is why NHT chose it after a *lot* of monkeying around with it...
Yes, I do realise that.
What I was trying to get at was that DEQX enables us to invoke a HP filter on the bottom of the midwoofer in a 2-way design, and the steepness of the slopes available (eg. 100db/octave) means we can run the midwoofer a bit lower than we could with a passive HP filter and thus reap the rewards of crossing over to the sub at a lower frequency.
A good active 12" sub would typically extend down further and flatter than a 12" driver in the main speaker box (plus be in a separate dedicated box that can be moved independantly of the main speakers and have adjustable phase, gain, LF rumble filters etc) thus providing a more effortless, extended and perhaps dynamic setup than a 3-way with a 12" woofer but no sub.
What I am wondering is whether you feel these benefits (on say a 1", 6", + 12" sub setup) equal or outweigh the benefits of a DEQX'd 3-way speaker with a dedicated midrange driver but no subwoofer (eg. 1", 6", 12", no sub)?
Are these factors somewhat dependent on the particular drivers or tied only to their size?
John, the more you shout how great the DEQX is, the less I'm inclined to try it.
Yikes...anyone catch Robert Greene's comments in the latest TAS on the DEQX'd Overkill system at CES? Damn, that is the first time I ever heard him say he had to leave a room (well, running actually) clutching his ears. This is the same guy that publicly drooled over the Dali Megalines (which is also somewhat uncharacteristic).John
Here's a speaker that is ideal for DEQX if anyone has $3K!http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1115308396 Also, FWIW, got my Xds in on Friday. Awesome.
Quote from: John AshmanHere's a speaker that is ideal for DEQX if anyone has $3K!http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1115308396 Also, FWIW, got my Xds in on Friday. Awesome.those suckers look awesome as-is.doug s.
Just realized those Audiom W 13" woofers go for about $1k each, so the price on these is really good. Maybe too good Don't want to burn myself if I touch them.Later in the week I'm going to drive down to their manufacturer http://www.celestialav.com to audition a similar pair. If I like them I just may buy this pair. At the least they would make nice rear channels I've asked more specifics about the "police action". Obviously I need to make sure they aren't stolen
yup, those focal drivers are fantastic
