DEQX Pdc:2.6
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
DEQX Pdc:2.6
« Reply #440 on: 14 Jun 2006, 01:24 pm »
Quote from: eduardw
Quote from: Rick Craig
There are some alternatives but nothing with all of the features that the DEQX has. What type of system do you want to use it with?
I want to do an active 2way bi-amp on a stereo system and I also would like to try the room correction features. It will also replace my pre and dac.
But I would like to see more manufactures making similar products.
As DSP costs come down I think you'll see more products like this but the marketing focus will most likely be toward the pro audio market.
Rick
obiwan11
DEQX Pdc:2.6
« Reply #441 on: 15 Jun 2006, 12:12 pm »
Well when I get to work tomorrow, I'm ordering a DEQX. I look forward to its arrival.
