Jim Griffin's white paper can explain it better than I can. The output of the array has more narrow dispersion and a cylindrical out put pattern. That's why you can be sitting in front of one speaker at a normal listening distance and distinctly hear the other channel (much more than you would with a point source). Jim and I are currently discussing his next array project that will implement the DEQX.
Hi John, They are Matrix 3 Series 2. .
Well, I think all speakers would benefit if they're tri-amped, but I do believe some speakers will have a greater delta in performance from stock to DEQXed. I think line arrays, for instance will benefit, but, for instance, DEQX lowers driver distortion and increases dynamic range, something most line arrays don't need to have fixed. Or, for instance, the enhanced vertical dispersion wouldn't be noticeable or particularly beneficial. It could, however, help a big speaker that moves a lot of air deal with ...
I think there are many types of systems that could benefit with possibly the exception of one (dipoles). I've had a chance to hear both the NaO dipole (basic active / passive combination crossover) and a dipole using the DEQX. The NaO was much better at depth retrieval and an overall sense of the acoustic space of the recording. I don't know what the problem was with the DEQX but I would be hesitant to use one with a dipole.Rick
That's what confused me, Jim seems to imply there is no enhanced vertical disperson, but, would the 3dB dropoff instead of 6dB allow the speakers to be more balanced? And, if that's the case, is that a wider radiation pattern or just the fact that the furthest speaker doesn't drop off as quickly as a point source?
What I don't understand is why someone would spend $3K+ to try to fix a $10K+ design that has inherent design problems that cannot be overcome. Why not buy a good speaker in the first place and then try to tweak it with the DEQX?
Btw, a speaker is a reproducer. Speakers don't "retrieve depth" or "throw images". When people speak of such things I tend to raise an eyebrow.
I guess the best way I can describe how they operate is to have you visit an owner of my arrays who lives in your area.
Quote from: Rick CraigI guess the best way I can describe how they operate is to have you visit an owner of my arrays who lives in your area. Let me know! He might be a customer. I'd be surprised if he weren't.
it wouldn't match up to what NHT is doing with Xd because Xd is the first speaker ever made that is designed from the ground up specifically for DEQX...
Do I know my B&W or WHAT? That's a 2.5-way. Great speaker, IMO, the best overall B&W made...
That's a pretty black and white statement to make. Is is based on your limited exposure to one NaO audition and another of a DEQX dipole in what I'm assuming were different listening environments?I may have some much more conclusive information to share shortly as I'm wrapping up a new dipole design which I plan to use with my DEQX. Btw, a speaker is a reproducer. Speakers don't "retrieve depth" or "throw images". When people speak of such things I tend to raise an eyebrow.
Cough. Well, yes, the XD's are first main-stream commercial speakers that are being sold with a "feature light" version of the DEQX PDC. The PDC has been available as a separate product for some time now and many people are using them quite effectively with their own designs or existing speakers. I for one bought mine before I ever heard about the Xd. I do believe that the Xd is a ground breaking product but also think that it can be bested if one carefully chooses a slightly different approach.
Your impression is exactly how I would describe my B&Ws, as "all-around" speakers. My questions were not really about how to integrate the DEQX into my current system, but to be able to understand how the DEQX works in an easy-to-describe way. So I used my current system as the example.
Yes but that is unfortunately cost prohibitive. I was thinking a way around this might be to run the low freq part out to a Behringer or analog xo to split the midbass from the bass.
The shootout I mentioned was with and without DEQX not with and without room correction.In terms of deciding what compromise you prefer that is the way to do it IMO.All analog/ passive crossover vs. a bi or tri-amped active system. You may say why bother DEQX will blow the analog system away. All I am saying is prove it. Again I do not doubt it but hearing is believing.I can tell you that room correction from a DBX DriveRack made my system sound like crap. Now I now a DriveRack and DEQX are not comparable just saying that I would need proof before making my system more complex.
It seems like many high-end enthusiasts have eventually gravitated towards high-efficiency speakers with a low-power amp, or towards planar speakers. Those have produced the most "wow" and have captured a lot of audiophiles. Now technology like the DEQX is producing a third type of "wow" and are drawing people to be as enthusiastic about this technology as they have been about the other two. Perhaps it is making the middle-of-the-road systems so much better that they don't need single-driver speakers or SET or planar speakers to produce that same intense enjoyment. Just my impression... ...
You can, but here's the thing - a secondary preamp would just add another analog circuit and lower the resolution needlessly. If you add a DAC, you would be going CD out to a DAC then to an ADC, then through a DAC again. But if you go digital into the PDC-P, you get only one DAC, with two steps removed. You could have a $20,000 DAC and/or preamp, but as soon as you put it in line, you are lowering the fidelity of the system as opposed to running straight into the PDC.The ONLY way to improve upon it without hurting the sound is to use bypass the AD/DA processes of the of PDC as well as its preamp function, keep it entirely digital and that requires 3 DACs, a switcher/AD coverter (a la Meridian) and a 6-channel analog preamp. So, I hate to say it, but your preamp and DAC would be obsolete in all reality.
