0 Members and 1 Guest are viewing this topic. Read 85488 times.
Hi Jim,Welcome to AudioCircle. Sorry to hear of your difficulties. Was Andre able to help at all?Where are you in So CA? Are you a member of the LA & Orange Co Audiophile Society?In any event, hope you can get it "dialed in". I may want to "pick your brain" a bit since I (if I ever get my laptop back) will be trying out the DEQX on my system.
Generally the dealer sends in your e-mail address and then DEQX contacts you with an "invitation" e-mail and then you follow the instructions.
Jim, In the afterthought department, it occurred to me you might be referring to unsmoothed comb filtering effects all audio systems are subject to--after years of looking at magazize articles that all post near field msmts, or use smoothing, it is a shock to see the raw response in all its glory. These tightly spaced vertical lines in close proximity look like noise and generally should be regarded as such--room treatment may reduce the amplitude somewhat, but they will still be there. If you have dip ...
Take your perfect(ly corrected) speakers and play pink noise in both channels, then walk in front of the speakers, parallel to them at the normal listening distance...
Fortunately, we don't listen to pink noise
If it is linear, then something is very wrong in the reproduction
Lobing, widening of the sweetspot has nothing to do with it.
For all the flat response, correction, perfect impulse response etc. fanatics ( no offense here, I WAS one of you) I'd suggest an easy experiment:Take your perfect(ly corrected) speakers and play pink noise in both channels, then walk in front of the speakers, parallel to them at the normal listening distance. You can hear huge tonality change in the pink noise as you move. And this is not coming from the room interaction. Actually the more treated the room, the more pronounced this comb filtering - 10- ...
If you believe that the sound of the noise should change when moving the mic or your ear in front of the speakers I'd be curious to hear your reasoning.
The "tonality change" is predominantly the result of the off-axis dispersion response of the tweeter. But, your assertion that room interaction is not responsible seems unfounded. "Normal" listening distances (as opposed to "near-field") are substantially affected by room acoustics, as evidenced by any near-field vs far field measurement (swept sine, MLS, etc). What is your basis for this assertion?
If you play the same signal ( pink noise or centered solo - but pink noise is better, because you are not emotionally connected to the tonalyty, your brain will not try to ignore the tonality change for the content) from two different distant sound sources, wild comb filtering happens at any point which is not exactly equidistant from the two speakers. Your two ears are about 6" apart, so they by default can not be equidistant from the two sources, so both hear very different freq response in the midrang ...
