0 Members and 1 Guest are viewing this topic. Read 85365 times.
the RM40s wouldn't be my pick for the most DEQX-able speaker as it would be hard to measure and correct....
Quote from: John Ashmanthe RM40s wouldn't be my pick for the most DEQX-able speaker as it would be hard to measure and correct....Even more of a challenge is the RMX. Its driver spacing is, um, er, hmm... let's just say that it's rather unconventional.
that kind of change will never be available to me unless I do another residency--say in cardiothoracic surgery
I've heard rumors of an upgraded PDC with better power supply and DACS -- any truth?...
Quote from: ekovalskyI've heard rumors of an upgraded PDC with better power supply and DACS -- any truth?...Well, if it's on the drawing board I'm not aware of it (not that I'm privy). My impression is that they have their hands full with software enhancements for their current product and getting their self-contained PDC/multi-channel amplifier finalized.
A "higher-end" model has been discussed, but with all the things on their plate, it's hard to know when they could get to it if at all. But, look, if you run digital out to the TacT amps and digital in, the power supply doesn't matter, it's not connected to anything that's analog. Use a Meridian or something as a digital switching device and run everything into it pure digital. But, as with many scientists, when you talk to them about better power supplies, the question for them is "why?!?" since the cur ...
Hell, I'm the one that brought up the damn coffee table to Florian in that post in the first place (my post is right under his first pix)!!!! I have a thick blanket on it, and underneath that blanket is some foam. It's fine, really. It's marble table that ain't gonna move for listening, then back again for HT chips-beer-what not. With the foam and blanket, and the side sonex first reflection points it's pretty good, I gotta tell ya.
And yes, Mac, I AGREE that I was using only 20% of it, and stated it in other posts more than a few times (I don't want to bash the DEQX; Kim, Ian and my wonderful dealer...he knows who he is....were very supportive.. )That's why I said the million lines of code for the FIR and room correction are State of the Art, no question. A bargain at $3k. I just didn;t like the DACS and am stuck with analog.
Now, maybe, DEQX will come out with a "high-end" model with a nicer power supply (its main arguable deficiency) for ~$5000 or so, and that would be nice, but I wouldn't count on it. It would be nice if someone like Conrad-Johnson could buy the boards from DEQX and do a tricked out version for $6K or so....
listen to Xd and then after a week or so, after you pick your jaw off the floor
I think the only limitation I can see with the DEQX for my application is more to do with its limit to 3 way only. The excludes 3 way plus sub or 4 way systems. That is a drag IMHO.
Oh, puleeeez.
Doug, there is a way of using your own preamp/DAC, etc, but it's a little complicated. First, you'd have to have a digital switcher, the obvious choice being something from Meridian - a 562 or a G91 or 800. The you take the digital out into the PDC that has digital outputs. Then, you go into 3 DACs of your own choice. Then you take the output of the DACs (2xtreble, 2xmidrange, 1 or 2xbass) and go into one of a very few analog 5.1 preamps such as the McCormack or McIntosh, then from their into 6 channels of amplification. So, you need to add 5 components to make this happen.If you put the DAC before the DEQX, it adds nothing but additional, though slight, distortion. If you put the preamp in front of the DEQX, you lose resolution. So the above way, which could cost you $5000+, even $10,000+ is the only way to do it that will actually improve your sound, not make it worse. Now, maybe, DEQX will come out with a "high-end" model with a nicer power supply (its main arguable deficiency) for ~$5000 or so, and that would be nice, but I wouldn't count on it. It would be nice if someone like Conrad-Johnson could buy the boards from DEQX and do a tricked out version for $6K or so. But would it sell? Hard to say. The DEQX has more appeal to the DIY guy than the "audiophile" because most audiophiles like to buy solutions or pay someone to do it for them, not tinker with it. But who knows, maybe all DEQX is missing is the right packaging (and power supply)?
