0 Members and 1 Guest are viewing this topic. Read 17870 times.
One more thing to add for anyone considering full range drivers vs. multi-way for classical music.Complex music, such as classical symphonies, creates doppler distortions when played on a single cone full range. The problem is the main cone is moving back and forth at a slow rate to produce the bass frequencies while at the same time portions of it are vibrating at much higher frequencies. This creates the doppler effect. Much the same as the variation in pitch that you hear when a vehicle siren moves towards you and then away from you.So when you combine lack of dynamic range, limited frequency response, and doppler effect with full range drivers it makes a very strong case in favor of multi-way speakers for full enjoyment of classical music.
Yes.And doppler distortion is somewhat disputed. A couple hearing text books i have read call it a red herring, but there are people who claim they can hear it.What is clear that if the music gets too busy, many/mist FR will start to get a bit “confused”. How much is, i guess, related to the listeners sensitivity to it and how lous thigs are being played. In my experience most people listen at quiter levels than others think they should.dave
Dave, I think again this has an awful lot to do with the type of music you are listening to and how loud it's played. There are some "industry experts" I've talked to who say that if a speaker sounds good with one type of music it will sound good with all types. I think they are entirely wrong. The dynamic range necessary for a symphony is much greater than for a jazz singer. And this is where I think the big difference between FR and multi-way comes in. Other things like distortions, etc., also play a role but to a lesser extent.PeterKK started this discussion based on his search for a good answer for classical music. That's why I keep getting back to this same point about dynamic range.
Extended range drivers make for excellent midrange drivers. That's how I'm using my Fostex F200a (rated 30-20,000 Hz), with 3 subwoofers and a pair of ambience tweeters.
So it sounds like this is essentially a 3-way system, not just a single driver implementation. But if the F200a goes from 30 to 20,000 Hz why do you need to add anything else.
That was my original thinking. But then read Floyd Toole, Earl Gedde, and Duke LeJeune. They support use of multiple carefully placed subs to help tame in-room bass peaks/dips (that can be 30 dB). Try measuring your room. (BTW also run Direct <500 Hz version.) I cross the subs over at 60 Hz and they go down to 20 Hz. The ambience tweeter was Duke's suggestion as the F200a is 8 inch diameter with no whizzer, so it beams above 4,000 Hz. The tweeter actually acts as a poor man's "Late Ceiling Splash" device, a Duke invention, which is my case helps boost treble response and solidifies/widens the soundstage. , and I really So I'm using the F200a as an extended midrange, covering 7 octaves.
That was my original thinking. But then read Floyd Toole, Earl Gedde, and Duke LeJeune. They support use of multiple carefully placed subs to help tame in-room bass peaks/dips (that can be 30 dB). Try measuring your room. (BTW also run Direct <500 Hz version.) I cross the subs over at 60 Hz and they go down to 20 Hz. The ambience tweeter was Duke's suggestion as the F200a is 8 inch diameter with no whizzer, so it beams above 4,000 Hz. The tweeter actually acts as a poor man's "Late Ceiling Splash" device, a Duke invention, which is my case helps boost treble response and solidifies/widens the soundstage. So I'm using the F200a as an extended midrange, covering 7 octaves.
