Anyone running with separate amp and active crossover for their bass drivers
0 Members and 1 Guest are viewing this topic. Read 15942 times.
HAL
Using the 12" Rythmik Audio and GR-Research servo subs in an open baffle H-Frame with DSP crossover using the Danville Signal dspMusik 2x8 system.   Low pass with an 8 pole L-R.  Also using timedelay to correct for distance offset between the planars and subs baffles.
Nice!  Yeah, the GR Research OB servo sub setup really is the very best bass system in the world at the moment.  And yes, I've heard most/all of the top high end stuff.
I gotta get over to your place someday & hear your fully active setup.
HAL
Sounds good.
If you go to RMAF2020, will have a room with the setup to listen to. :)
