0 Members and 1 Guest are viewing this topic. Read 14664 times.
Funny how a bunch of people just got done telling me that it doesn't do anything
It's not that it doesn't do anything, it's that when the damping factor gets well above 10 it's further impact quickly diminishes.What they are hearing is the effect of added series resistance causing response changes with frequency. Just look at the Stereophile measurements of some tube amps (just about the effect).
The explanation covers only half the story.Effective Damping Factor values for calculation includes: > 1 run speaker cable > resistance of crossover elements > voice coil resistance > 1 run of speaker cable(ignoring for the moment the effect of various connectors, etc which would further increase the above value).A value of 20 or higher is adequate.
Lower damping factor means less control over the speaker. More control typically means better, more accurate sound.
+1Or another way of putting it, anything over 20 brings you vanishingly little.dave
Based on what? I've heard the difference, and much more. So you know I'm not just making baseless claims, I'm an electrical engineer with 30+ years experience in audio (consumer and pro), plus military, medical, fire safety, and even toys.
Me too. And possibly over a much wider range of loudspeakers. 45+ years in audio. And while no engineering degree (1st half of one, but i started with an honours math degree 1st) an engineering mind. And i like to leave it open. Engineering will let you comfortabley generate numbers, but if you include everything in the circuit and damping factor greater than about 20 adds vanishing little to the end result. Much as Johnny2Bad has already done for us in this thread.dave
… you're using an already handicapped tube amp with poor damping factor, rolled off highs, and high noise, for example. Have you ever heard a Cherry Amp?
… how much better it mated with my speakers…
F. Langford Smith wrote about this in 1947.Industrial audio consultant Dick Pierce wrote this paper in 2002:"Damping Factor: Effects On System Response"Dick PierceProfessional Audio Developmenthttp://www.cartchunk.org/audiotopics/DampingFactor.pdfhttp://www.cartchunk.org/
Not one mention of speaker reactance! Translated: obvious bias toward low performance amplification
That's because system 'Qr' which is what this is all about is measured at resonate frequency where the reactances cancle out.
Zero output impedance is ideal
Ever wonder why some amplifiers "can't handle" low impedance speakers?
Amps with very poor damping factor (non OTL tube amps, for example) can't fight much against the back EMF of the speaker.
This causes a "sloppy sound", especially noticeable in the bass.
most amps with great damping factor only have that characteristic at low freq (100Hz and down)
\https://hometheaterhifi.com/technical/technical-reviews/a-secrets-technical-article/
