How much power does a Larger sub need?
0 Members and 1 Guest are viewing this topic. Read 14544 times.
ctviggen
« Reply #40 on: 13 Jan 2005, 09:05 pm »
That is true.  I just just thinking it would be fun to play around with the Eq to see what happens.  In the end, I'll likely get a TACT, but the TACT is a lot more than a simple Eq.  For right now, I'm just looking at options, and don't want to spend the money for a while, if possible.  I need to do the putty adjustment on the Larger and see what happens.
ctviggen
« Reply #41 on: 13 Jan 2005, 09:10 pm »
I should've said "a lot more money" than a simple Eq (and, granted, a lot more functionality, too).
doug s.
  • makin' music
« Reply #42 on: 13 Jan 2005, 09:47 pm »
bob, for the money, you could pick up a used qsc amp and a used eq (like behringer, dbx, etc), for not much more than a pair of those plate amps, if that much.  then, when yure ready to move up to a tact or sopmething similar, you will still have left a killer sub amp!   :wink:
doug s.
ctviggen
« Reply #43 on: 13 Jan 2005, 10:21 pm »
I wasn't thinking about that -- two plate amps would be about $800, and a used QSC wouldn't be too much more than that and could drive two subs (or really, really drive one).  Good idea!
doug s.
  • makin' music
« Reply #44 on: 13 Jan 2005, 11:12 pm »
Quote from: ctviggen
the particular amp that i posted f/a will not even make it to $800, & it's really quite the monster amp; smaller ones, still more than adequate for vmps subs, imo, will certainly sell for less.  here's another 3002 for "buy-it-now" of $620:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=23787&item=3775723824&rd=1
lots of these on ebay, a search for "qsc plx" comes up w/these:
http://search-desc.ebay.com/qsc-plx_W0QQsofocusZbsQQsbrftogZ1QQcatrefZC6QQsojsZ1QQfromZR10QQcatrefZC6QQftsZ2QQftrtZ1QQftrvZ1QQsadisZ200QQfposZ20892QQfsopZ1QQfsooZ1QQcoactionZcompareQQcopagenumZ1QQcoentrypageZsearch
even the mondo plx 3402 usually goes for <$800; see completed auctions:
http://search-completed.ebay.com/qsc-plx_W0QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfisZ2QQfposZ20892QQfromZR10QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQftsZ2QQsadisZ200QQsbrftogZ1QQsofocusZsoQQsojsZ1
even the "baby" qsc plx 1202 makes 200wpc-8ohms/325wpc-4ohms...  if i dint awreddy have a nice pair of electrocompaniet amps to use for sub amps, i'd go w/the qsc's...
but, i am not sure i'd bridge 'em; for a pair of the larger subs, i'd run a pair of stereo amps, w/each amps' channel driving a separate woofer.  usually (but not always), running an amp non-bridged will give better sonics than bridging.  i had a pair of original-iteration adcom gfa555's that were relegated to subwoofer duty before i replaced them w/the ec amps.  even w/only one channel of each amp driving each of the larger subs, (before i got a second set of binding posts to use both amps' channels), the subs sounded better than when i ran them in bridged mono...
regards,
doug s.
brj
« Reply #45 on: 14 Jan 2005, 12:45 am »
I'm not that familiar with these amps, but isn't it something of a concern that they don't double their power from 8 Ohms to 4 Ohms when considering them for sub duty?  Subwoofers tend to be current hungry, and I was under the impression that the "doubling" characteristic was one of the prime indicators of a high current amp.
I didn't really notice the specs before, and Brian's recommendation goes a long way, so I was curious about the apparent dichotomy.
doug s.
  • makin' music
« Reply #46 on: 14 Jan 2005, 08:01 pm »
Quote from: brj
specs can be misleading - sometimes mfr's will intentionally "under-rate" the power at 8 ohms, so they can say the power doubles.
in any ewent, in this case, the power increase as ohms drop is still adequate, imo, & they are stable to at least 2 ohms.  this, combined w/a damping factor >500 seems to indicate these spec extremely well for subwoofwer amps.
doug s.
ctviggen
« Reply #47 on: 14 Jan 2005, 08:06 pm »
I noticed that the winner of one of the auctions was a jgubman.  Isn't there a jgubman on this site, too?
doug s.
  • makin' music
« Reply #48 on: 14 Jan 2005, 08:09 pm »
a search of his name comes up w/181 matches...   :wink:
doug s.
jgubman
« Reply #49 on: 14 Jan 2005, 08:32 pm »
You caught me, I grabbed the "Buy It Now" 3002 for $650 shipped yesterday. Works out to be less expensive than buying 2 of the 1000W plate amps.
Will be powering a pair of Megawoofed Largers with the 3002, I'll let you know how it works out.
BTW, this subwoofer change will be replacing a pair of SVS 25-39CS subwoofers powered by a 150w x 2 Fidek amp. I'm expecting a big improvement.
ctviggen
« Reply #50 on: 14 Jan 2005, 09:01 pm »
Aha!  Nabbed 'ya!  Let me know how that turns out.  I have one Larger and one SVS 25-39 (powered by its internal amp).  I want to get another Larger and then either keep the SVS for another corner (for movies) or sell it.
zybar
« Reply #51 on: 14 Jan 2005, 09:16 pm »
Bob,
I have an excellent condition PLX3402 that I will sell for only a little more than it's baby brother that was just bought.
If anybody is interested, you can read my original post here:
http://www.audiocircle.com/index.php?topic=10776&highlight=
George
jgubman
« Reply #52 on: 14 Jan 2005, 09:27 pm »
Damn you zybar, I actually was reading that post yesterday as I was quickly doing some last minute research on the QSC...
I figured there was no way you still had that amp, otherwise I would've bought yours in a heartbeat...
damn
brj
« Reply #53 on: 14 Jan 2005, 09:35 pm »
George, did you ever get around to the comparison with the K2?
zybar
« Reply #54 on: 14 Jan 2005, 09:38 pm »
Quote from: brj
Sorry to say I didn't and I probably won't have time to...just not enough hours in the day.
George
jgubman
« Reply #55 on: 15 Jan 2005, 03:22 am »
So how are you guys hooking up your sources to these pro amps?
I currently have a RCA cable going to a RCA -> 2 RCA y-cable going to two RCA -> 1/4" Phono plug adaptors -> amp.
Does a more elegant solution exist? Is there such a thing as a Female RCA -> 2 1/4" phono plug y-cable? How about Female RCA -> 2 XLR y-cable? I'm guessing a RCA -> XLR wouldn't be optimal for gain reasons...
grub
« Reply #56 on: 16 Jan 2005, 12:09 am »
I have a QSC RMX 2450 I recently purchased to power my sub (wich will be replaced with a Larger sub sometime in the future).
It's heavy, has loads of power, and an annoyingly loud fan.  I'm looking into the fan problem and I may have found a solution.
Thankfully, QSC uses a fairly standard 80mmx80mm fan (like the ones inside a computer), but they run a 24Volt fan instead of 12.  I've ordered a quiet fan from an online computer store, and I'm planning on cutting the voltage with a 12v regulator.
I'll report back with results.
-->grub
ctviggen
« Reply #57 on: 17 Jan 2005, 06:13 pm »
I was going to do RCA to XLR, if I can have a cable made.  The QSC website has a user's manual that shows how to make the connection for the XLR in unbalanced mode:
http://www.qscaudio.com/products/amps/plx/plx.htm
jgubman
« Reply #58 on: 12 Feb 2005, 09:31 pm »
Well, I finally got the PLX 3002 (eBay shipping nightmare...) and hooked it up last night.
I was using a Fidek FPA-3002 (300W x 2) and the QSC seems to have a little more authority.
However, the fan noise is killing me. I can't live with it.
Has anyone used the QSC w/ the fan unplugged? The Fidek had a similar fan noise, and the fan was removed a few years ago and the amp has been fine. I wonder if there'd be a problem doing the same to the QSC, otherwise, I'll have to hunt around for a K2...
zybar
« Reply #59 on: 12 Feb 2005, 09:50 pm »
Quote from: jgubman
If you need a K2, shoot me a PM.
George
