0 Members and 7 Guests are viewing this topic. Read 387287 times.
The Sabaj has 2 sabre chips; the smsl has built in battery. Will be interesting to see a comparison.
Wow, it seems to be exactly the Sabaj! I'd probably just get that one...and save $40.
The SMSL IQ looks to have less power on the headamp, however it does have selectable DSD filters. I don't think the DA3 has that.
Can't seem to find any info on battery life. Otherwise looks like the same design as the DA3, but with better portability. Looks like they read the feedback on the DA3.
Wonder what the difference is with the new XMOS driver vs 4.11.
Could someone please explain with links to the identified components how to add an external linear power supply to suppott the da3. Also confirm that the increase in sound quality justifies the investment.
"iDefender3.0 USB Ground Loop Eliminator" seems to be the wisest and easiest way to power it. If you think it as a big investment I think you should just wait and buy a chord mojo. I don't think you can confirm it without trying it yourself, you might find it a little bit bright. Using it with Shure se846 with red knowles filters and loving it.
Hopefully the combination of the idefender, ipower and sabaj da3 with DSD512 will not be far off the Mojo DSD256 at 40% of the cost..
Wow, it seems to be exactly the Sabaj! I'd probably just get that one...and save $40.-Jim
Even if an amateur like me, the sound quality is higher than sabaj da3.(At least the built-in power supply did not adversely affect.)
What files did you compare?Did you compare some DSD files?
Don't get too comfortable with that new SMSL. Look what's within striking distance of that price:https://www.ebay.com/itm/TOPPING-Takumi-NX4-DSD-fever-HiFi-portable-decoding-amp-ES9038-USB-DAC/272972594580?hasheven cheaper here:https://www.aliexpress.com/item/Upgrade-Version-Topping-NX4-DSD512-ES9038Q2M-XMOS-XU208-chip-Portable-USB-DAC-Decoder-32bit-768kHZ-Headphone/32843177203.html?ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10130_10068_10344_10324_10547_10342_10325_10546_10343_10340_10548_10341_10545_10084_10083_10307_10059_10314_10534_100031_10604_10103_10142,searchweb201603_40,ppcSwitch_5&algo_expid=a0fa8564-3f04-4c4d-9638-5cf774dda487-0&algo_pvid=a0fa8564-3f04-4c4d-9638-5cf774dda487&transAbTest=ae803_4&priceBeautifyAB=0Like I said earlier, the upgrade cycle on DACs is now 6mo. or less. I'll wait another cycle then maybe get one of these es9038s once the price comes down.
WushuliuBack on page 7 or so. You mentioned this was on your headphone rig and you planned on setting it up on your 2 channel rig I believe. Did you get this done and do you have any thoughts on it? Does anyone have any experience with this on a mac mini or similar? Something other then PC or phone/tablet? Any reason to believe why it would give me an issue on my Mac? I see there is a balanced XLR https://www.ebay.com/itm/Gotham-Astell-Kern-Opus-DP-X1-2-5mm-TRRS-Balanced-XLR-Output-Cable-1-0M/112579597019?hash=item1a364452db:g:A3UAAOSwM6ZZy6QsI couldn't find something similar for an RCA. Would it matter if I just used a 3.5mm to rca connector to my preamp?Thanks all
