More Amazing DACs for Peanuts
0 Members and 7 Guests are viewing this topic. Read 387359 times.
zek
Re: More Amazing DACs for Peanuts
« Reply #120 on: 28 Nov 2017, 01:00 pm »
bixby
« Reply #121 on: 28 Nov 2017, 05:39 pm »
psst, best dac I have had in my headphone system in years!  No noted faults so far.  Topping D30
wushuliu
« Reply #122 on: 28 Nov 2017, 06:24 pm »
The Topping uses the CS4398, which I agree is a great sounding chip and deserves more love. It's got a 'lively' presence to it and an engaging midrange.
Not a fan of the OPA2134 opamps the Topping uses though. Are you able to swap them?
wushuliu
« Reply #123 on: 28 Nov 2017, 06:32 pm »
i started looking atthese because i am hoping to get Xmox 208 and RCA outputs and also headphone output and also stay away from ESS
For greatest flexibility my thought is get one of the many XMOS 208 cards available and then you can use whatever dac you want.
https://www.ebay.com/itm/Assembled-XU208-XMOS-USB-Audio-Digital-Interface-XLR-AES-fiber-coaxial/112402255126?hash=item1a2bb24d16:g:sugAAOSwR29ZEqA5
(just one of many at different price points).
wushuliu
« Reply #124 on: 28 Nov 2017, 06:36 pm »
Current update: still loving my DA3. Will try to make a balanced output cable for my amp and try that out. My setup sounds gorgeous, but it's really the emphasis on power supplies that took it over the top (lot of LT3045s in this case). If it's a choice between a cheap dac and a great PS vs a pricey DAC w/ stock, I'll take the former every time.
jmc207
« Reply #126 on: 28 Nov 2017, 06:41 pm »
The pictures I've seen of the D30 circuit board show a soldered OPA2134, though there is someone who unsoldered it and replaced it with a socket.
maty
opamp CM Impedance Distortion
« Reply #127 on: 28 Nov 2017, 06:46 pm »
wushuliu
« Reply #128 on: 28 Nov 2017, 06:46 pm »
Master Index for Audio Hardware Reviews
https://audiosciencereview.com/forum/index.php?threads/master-index-for-audio-hardware-reviews.2079/
-> Topping D30 DAC Measurement and Review
https://www.audiosciencereview.com/forum/index.php?threads/topping-d30-dac-measurement-and-review.2016/
Mmm, yeah, Amir. Whatever.
He does like the Topping though. Sounds like its headamp is the key here based on bixby's statement above.
wushuliu
Re: opamp CM Impedance Distortion
« Reply #129 on: 28 Nov 2017, 06:47 pm »
restrav
« Reply #130 on: 28 Nov 2017, 06:49 pm »
Which one? :roll:
this one.
https://www.ebay.com/itm/263051265833?var=562053792431
im checkling out Topping d30 right now. i dont know anythiong about that DAC chip. so far between the ones that i have heard i prefer AK4490 to any ESS but really the only sound that i really like has only been from philips good old NOS DACS. the only  reason that i am not going for another one of those is only that i want a good headphone amp and cutting edge USB right now.
maty
« Reply #131 on: 28 Nov 2017, 06:49 pm »
More:
Attached measures the buffer designed by us using different operational amplifiers:
http://www.atmstore.es/en/buffer-nc500-3/
My conclusion: do not buy Burson Audio V5
restrav
« Reply #132 on: 28 Nov 2017, 06:51 pm »
D30 does not have a head amp it seems. i 1st prioraity is a decent headamp with (ideally) half watt or something like that . i want to drive some planars with it. i think im done with dynamic headphones.
restrav
« Reply #133 on: 28 Nov 2017, 06:53 pm »
i dont care about DSD much at the moment, i want the XMOS usb for the fidelity it supposedly provides. i have like 5 DSD albums but i dont really care about any of them. i want something that makes my radiohead, portishead, pink floyd and leonard cohen sound good.
wushuliu
« Reply #134 on: 28 Nov 2017, 06:57 pm »
Ah, I misunderstood bixby's post. Thought it did. If a headamp is important, you should just buy a separate headamp. Can start with a good old CMOY mint tin on ebay if you're cash strapped.
restrav
« Reply #135 on: 28 Nov 2017, 07:00 pm »
More:
edited: I also returned the LKS which proved that specs mean zero.
wushuliu
« Reply #136 on: 28 Nov 2017, 07:04 pm »
i bought V5i last year i tried it in my LKS DA003 and i sent it back for refund. i was one of the early adopters.
I also sent the returned the LKS which proved that specs mean zero.
I think opamps are best avoided in general. Kind of like tubes, you just ended up spending a lot of money trying out one after the other, chasing your own tail. At least tubes are cool. I just a built a tangensoft MINT headamp, so I shouldn't talk, but I also had a lot of opamps sitting around for years so I put them to use.
bixby
« Reply #137 on: 28 Nov 2017, 07:28 pm »
As mentioned no headamp in the Topping D30.  I run it into a Magni3.  This Aprox $200 combo gives me more satisfaction than a Schiit Modi 4490 and Lake People GS-109 at about
3 times the price.
As for chips, my experience is they can sound similar in lower cost implementations but they are not the biggest factor in some higher priced dacs ultimate sound, but do have a role.  My main speaker dac (Prism Lyra 1) also has 4398 chips but should not be lumped in the same league as the Topping.
maty
« Reply #138 on: 28 Nov 2017, 07:34 pm »
Opamp, better a discrete opamp like Sonic Imagery SIL 994 Enh Ticha
http://www.sonicimagerylabs.com/products/Model994DiscreteOpAmp-Ticha.html
or someone of the new opamps.
It is very important how they have been implemented in the circuit.
maty
Second harmonic preminence
« Reply #139 on: 28 Nov 2017, 07:42 pm »
A very clean system can sound "anechoic".
That is I am interested in preamps with second harmonic preminence + clean power amp + clean DAC.
http://www.audiocircle.com/index.php?topic=153645.msg1646998#msg1646998
I am not Mike but my idea was a preamp with second harmonic preminence, very low third harmonic and nothing else. With clean DAC (maybe the RME ADI-2 Pro - I love RME AD hard used to make vinyl rips). The sound profile would be given by the preamp.
Look at the graphs of this new DIY preamp by xrk971 + AKSA.
AKSA's Lender Preamp with 40Vpp Output
http://www.diyaudio.com/forums/solid-state/314563-aksas-lender-preamp-40vpp-output.html
Well it is not balanced but... the measures are so beautiful aka very clean.
Oh, you need to be logged to see the pictures. Maybe I can upload one:
[IMG] http://maty.galeon.com/WP-imagenes/hum/AKSA-Lender-Preamp-SMT-Preamp-20vpp-7kohm-47R-degen-yes-matched-6k8carbon-FB.png
