0 Members and 7 Guests are viewing this topic. Read 387360 times.
>>How's SE-MHR5 with Da3 balanced VS unbalanced? Is it possible for you to compare?Sorry, SE-MHR5 contains 2.5mm balanced cable only.Comparing with SE-MS7BT (Balanced), I think that the resolution clearly exceeds (Personal opinion to the last.)>>Why would you use Da3 with M1? Although M1 can play only up to DSD 128 by itself, but it can outputs DSD 256,512(Amazing!!!) without difficulty to the outside from USB.(FW4.1)>>Is it so noticeably better than AK4452+MAX97220 of M1?I think that there is an effect of balance connection and it will not be comparable.(Personal opinion to the last, too.)
>>Why would you use Da3 with M1?Although M1 can play only up to DSD 128 by itself, but it can outputs DSD 256,512(Amazing!!!) without difficulty to the outside from USB.(FW4.1)
On the other hand, Shanling says in the release notes of FW 4.1 as follows."2. Added the DSD native digital output mode."Does this mean that it is a pseudo NATIVE DSD due to the characteristics of the pointed DAC chip?I do not know when it will be answered but I tried throwing a confirmation to VENDOR as well.
My topping D30 has a defect. We'll see how well the ebay seller stands behind this product.
I received a modified version of daphile and can confirm daphile WILL support native dsd512. The sound is incredible for the price but you need a good CPU. I use an i3 8100. Hopefully the daphile update will be included in the next beta.
Is it possible to x3 da3 for 5.1 system? or am I just silly?
How will you split a digital USB signal into 3 parts???
My topping D30 has a defect. When presented with low rumbling bass it distorts badly like an amp clipping. It is repeatable and amp, headphones, speakers have been ruled out. It is not a particularly loud passage so hard to believe a 0db event or an over.For the record the input is usb using asio. We'll see how well the ebay seller stands behind this product.EDIT 12-20 ebay seller is cybereveryday. Advertised the dac as being USA stock shipping from Los Angeles. Now to return the item wants me to pre-pay shipping to CHINA. Still working on a refund.
SMSL released an "answer" to Sabaj's Da3 - dual Sabre DAC with balanced HP output and a built-in battery - SMSL IQ....Happy New Year!
SMSL released an "answer" to Sabaj's Da3 - dual Sabre DAC with balanced HP output and a built-in battery - SMSL IQCurrently available for $139.99 @ amazon.comAlso there's a new windows driver for XMOS based devices - 4.38.0Happy New Year!
Wow, it seems to be exactly the Sabaj! I'd probably just get that one...and save $40.-Jim
