0 Members and 7 Guests are viewing this topic. Read 386625 times.
any new finds that sound better so similar to sabaj DA3?
I've gotten the idefender+ipower couple lately to power the DA3. If I had to describe the changes I would say the sound gets clearer, more natural and dynamic. The stereophony becomes larger, gets way deeper, the instruments don't overlay each other anymore in the depth. The sound from the DA3 was already really good by itself. The couple just improves it further. At the price point of the DA3 I dunno if it's worth it though, it doubles its price. Still I'm glad I invested in it knowing I will use it every time I get a new usb DAC (if it doesn't die on me ).
This is a very interesting device indeed! With a flagship mobile ES9038Q2M DAC, battery, etc... But is it a major upgrade or even a different league comparing to SMSL IQ or Sabaj Da3 ? Technically on paper for sure it is but how different is it in real life in that particular device?
What's the amp chip used in Topping NX4 DSD? Is it the same OPA1642+LMH6643 combo found in the original NX4 or a different set?Using SABRE9602 amp will make 9038Q2M sound very close if not identical to 9018Q2C. Using TI's stuff like OPA1622 will make it sound different I guess, maybe even better.EDIT: Ok, it's OPA2140-based, no additional info though.
hard to know but it's able to run just as amp as well, which could be useful at times (e.g. on a plane).It has a line out which (I assume) bypasses the headphone amp.Like I need another DAC/amp, but still....PS. Here's the manufacturer's page: http://tpdz.net/en/products/nx4dsd/index.htmPPS. Also available now via amazon
It seems no-one's got the NX4 (DSD) yet, anyway I just ordered one so will report back. I'm assuming (hoping) that being battery powered it will work from my iPhone/iPad. Plus with the line in it can be used in planes etc. We'll see.
Investing in the cleanest power supply you can manage outweighs the value of the dac. This Lipo4(?)/LT3045 battery option showed up recently. I don't see the iPower competing with it, especially for the cost. https://www.ebay.com/itm/LT3045-Battery-Regulated-Power-Supply-5V/273135946356?hash=item3f982bca74:g:vFIAAOSweq5av1nPIf you have the skills and want to really take your dac to a new level, replace the iPower with not one, but *two* LT3045 low noise regulators in series. I have a 6v board that feeds a 5v board. I can't overstate the impact. Floored me.
Awesome!
Looks like they put it on the slowest boat they could find Anyway I'll update when it arrives.
In difficult choice between Sabaj Da2 / Sabaj Da3. But anyway I'm not going to use balanced headphones or headphones with impedance higher than 100-150 (now using 32-70). Question: Is there any other reason to buy Sabaj Da3 instead of Sabaj Da2? Is there any big difference in sound, other then balanced output, and ability to power higher impedance headphones?
how about using isilencer after ipower to feed the dac?
Also will usb 5v board that feed 5v board work for usb dacs?
? Not sure what you are referring to.
I'm thinking of doing a usb to usb with two 5V 1A LT3045 dongle for sabaj and for my other other usb only dacs.
