0 Members and 7 Guests are viewing this topic. Read 386617 times.
Investing in the cleanest power supply you can manage outweighs the value of the dac. This Lipo4(?)/LT3045 battery option showed up recently. I don't see the iPower competing with it, especially for the cost. https://www.ebay.com/itm/LT3045-Battery-Regulated-Power-Supply-5V/273135946356?hash=item3f982bca74:g:vFIAAOSweq5av1nPIf you have the skills and want to really take your dac to a new level, replace the iPower with not one, but *two* LT3045 low noise regulators in series. I have a 6v board that feeds a 5v board. I can't overstate the impact. Floored me.
Looks like they put it on the slowest boat they could find Anyway I'll update when it arrives.
You mean powered externally from like an idefender? What is the power source? You need at least 5.5v source to the LT to get 5v out to a dac.
Duo you have the da3 to compare it with?
No (?)The NX4 should work with my iphone but I don't think the DA3 will (current).
this is the weirdest one i have seen so far. i mean i know for sure, that USB decoder chip can not support hi rez
I decided to pick up a DA3 for my desktop setup (HD6XX.) Obviously, the DA3 is a bit underpowered for them -- what's the best way to use this as a DAC running into an amp? Full volume, or drop it a bit? This doesn't seem to put out a lot of power, so I'm thinking max volume is the best to simulate an aux out type of thing.Thoughts?
For SennHDs I would recommend getting an external amp as well. The DA3 can drive your phones, but they won't sound their best.
Oh, I've got it plugged into an Aune X7S (magical) but am wondering if I should set the DA3 to max volume (currently doing so, without noticeable degradation)
Hey guys , help me please i wanna buy sabaj da 3 or smsl iq for using it with oneplus5t + sony xba n1ap only which one should i use ? cuz idk about android working good with thoses and my hp
Sabaj da 3 works fine but drinks battery. Go for smsl iq. Also buy an isilencer
