0 Members and 1 Guest are viewing this topic. Read 39471 times.
I believe Andrew hedged when he said a $4000 amp with $500 UB-5 passive would be the audiophile's first system and the $750 UB-5 active would be the audiophile's second system. First, as mentioned a $4000 amp on $500 speakers is ridiculous as is the combined 1:6 price differential. Secondly, he has to give in to market demands as most audiophiles want to be audio chefs and select their own ingredients to come up with their own creations (a control issue). Third, he does want to alienate that audiophile mainstream. Fourth, many established audiophiles would be embarrassed to have such a simple, inexpensive system as he was displaying.
I'd like to see clarification that these are active design (low voltage crossover feeding each amp and one channel of amplification per driver) versus powered (simply amps built into passive speakers as per the signage above the ELAC display on the video). This is a sloppy use of terminology that hurts the cause for active design.
Is there anyone who manufactures "audiophile quality" active speakers? I mean someone like a Daedalus or Salk or Vapor Audio or GR Research that typically uses high quality parts and takes aesthetics seriously. As an audiophile, I don't want a cheap $30 plate amp attached to my speakers like most other active monitors. I'd also like to see integrated speaker stands to hide the power cords and ICs for monitors, and full range floor standers to eliminate the need for separate subwoofers (i.e., wife friendly). All of this should be available at a price significantly lower than my current speaker/amp combo without losing fidelity. IMO, if the cost is comparable or higher than what I already have, there's little incentive to consider active speakers.
I'm going active. I just ordered a pair of JBL M2s and a DCi 4|600 amp. That is 600wpc into 4 channels for biamping them.
When I hear "Active" and "Audiophile" in the same sentence, the first name that comes to mind is Linn.
I'm confused by how you guys are thinking about active speakers. I used to actively triamp Yorkville Unitys, meaning I had a 6-channel DAC that output to 3 separate stereo amps and then on to the drivers, directly. Zero passive crossover components in the signal.I used Audiolense to construct convolution filters which allowed the above to occur - with room correction.It's pretty awesome but a lot of work.Now I use powered "monitors" (QSC floorstanding 3-ways). I saw these (or similar) at a lot of the music venues I go to...so figured I'd have a set home to best duplicate the live experience.Are the active monitors here ones that convert to digital and then apply dsp? I assume so, unless they have a digital input.
