0 Members and 1 Guest are viewing this topic. Read 39474 times.
Active speakers are better if they use a good (bi) amplification and active crossover.Nearfield monitors (pro)* But most uses cheap amps to reduce costs.* Good amplification in class D costs money.* Class AB many use monolithics, with low slew rate!!! 10 V/microS is very common * And PSU are also bad.* Manufacturing quality has gone down a lot these years.It is better a good passive speakers with a good second hand class AB amp or expensive like Neumann KH 120 A, Genelec... if you want to listen very good records.
...though a partially active system may have one amp channel for the woofer with a second amp channel driving the mid-range and tweeter through a passive crossover. Taking the woofer out of a passive speaker level crossover provides the biggest bang for the buck. (The woofer generates, by far, the largest back-EMF, etc.).....
Note that a fully active speaker system has a separate amplification channel connected to each individual driver, though a partially active system may have one amp channel for the woofer with a second amp channel driving the mid-range and tweeter through a passive crossover. Taking the woofer out of a passive speaker level crossover provides the biggest bang for the buck. (The woofer generates, by far, the largest back-EMF, etc.)
This how my Soundfield Audio Monitor 1 speakers are designed.
confused here,Andrew mentions in the video 3 way fully active system,to me that means tri amping,some of you mentioned mid/tweeter common,if it is bi amping my appologies to maty...
Again just another passive speaker that happens to have an active subwoofer (of sorts) built-in.It's always perplexed me as to why audiophiles who shy away from active speakers use powered subwoofers which in effect are active speakers.
And again, from the research Floyd Toole has done, ideal mains and sub locations do not coincide.
Yes, AJ I'm a big fan of active speaker design.
All the swarm readings I've found (primarily Toole's book "Sound Reproduction") suggest multiple asymmetrical subwoofer layout is the preferred way to even out in-room bass response below the Schroeder "cross-over" frequency, something like 12", 19", 31", and 50" from corners.
I'm going active. I just ordered a pair of JBL M2s and a DCi 4|600 amp. That is 600wpc into 4 channels for biamping them.
Congrats Josh! I figured the demo would eventually push you over the edge! I can't wait to hear them for myself. I don't see in the DCi 4|600 manual any reference to built in DSP functions. What are you using for xo?
