Andrew Jones discusses pros and cons of active speakers
0 Members and 1 Guest are viewing this topic. Read 39472 times.
undertow
Re: Andrew Jones discusses pros and cons of active speakers
« Reply #80 on: 21 Jun 2016, 08:34 pm »
I agree, the vast majority of audiophiles choose passive xo, because it's good enough for them. But there is more to be had with active/DSP, so its pursuit is valid, imo.
Right... But to go back a couple of comments directly from me... I was illustrating a passive XO on 50hz and above can be just as efficient, and accurate in many systems even vs. active if done right. Of course normally cheaper and simpler as well. Big BASS re-enforcement is a whole other story, but luckily active sub setups are in droves, and many many flexible options out there on that end of spectrum.
Russell Dawkins
« Reply #81 on: 21 Jun 2016, 08:50 pm »
I've had many great sounding combos with passive speakers and an amplifier, yet at least in the budget realm, quite a few people think for $300 the JBL LSR305 sounds much better than $200 passive speakers and a $100 amp, so maybe for those non-critical budget applications it makes more sense?
...in the same way as $750 for a tri-amplified UB5 would make more sense than a UB5 and a $250 amp.
Joe Fonebone
attention moderator -ELAC active UB5 question
« Reply #82 on: 21 Jun 2016, 10:05 pm »
Has anyone heard when the active UB5's will be released?
JeffB
« Reply #83 on: 21 Jun 2016, 10:51 pm »
Elac website says they will be available July 5.
JeffB
« Reply #84 on: 21 Jun 2016, 10:58 pm »
My issue with active speakers is simply how to connect to them.
I always find it strange that one can buy a $200 surround processor with 7 amps and a remote control, but if one wants just a surround sound preamp, then you are looking at least $2000.  Any money possibly saved on the speaker is totally blown on a preamp.  The situation is a little better if one only needs 2 channel stereo, but not if you want remote volume control.
Russell Dawkins
« Reply #85 on: 21 Jun 2016, 11:07 pm »
Another argument for two channel! :thumb:
I'm all for the simplest solution. Life's too short for surround!  :peek:
Joe Fonebone
« Reply #86 on: 21 Jun 2016, 11:34 pm »
The only July 5 release I see on the ELAC site (at least here in the US) is for the passive UB5 @ $499. Do you have a link for the active UB5s? Thanks.
rajacat
  • Washington State
« Reply #87 on: 21 Jun 2016, 11:46 pm »
Perhaps the next wave of innovation will be in the area of driver design. If you can design both drivers in a 2 way so that the FR is very flat and one driver naturally rolls off as the other one naturally comes in then you wouldn't need any crossover at all and the SQ wouldn't be hurt by passive or active components. You could physically line up the voice coils to control phase issues. It would be optimum if both drivers were of equal efficiency. Waveguides could help with directivity in the upper frequency region.
DaveC113
  • ZenWaveAudio.com
« Reply #88 on: 21 Jun 2016, 11:55 pm »
Yup!  :thumb:
2-channel is capable of more than most give it credit for...
I suppose though, if I had unlimited funds I might have a MCH theater system too. Just call the JBL dealer and have the Everests installed...  :D
raja, that has been done to a certain point... some Avantgardes and Pipe Dream speakers run the mids without an xo.
JeffB
« Reply #89 on: 22 Jun 2016, 12:38 am »
@Joe
Sorry, I don't know when the active UB5 will be out.
At The Show in Newport, Elac discussed having a standalone amplifier around September.
Russell Dawkins
« Reply #90 on: 22 Jun 2016, 12:39 am »
But with that scenario, the energy to their voice coils that was outside the desired passband would be heating the coils and needlessly lowering the thermal compression threshold. This would apply particularly to the mid and high drivers in a three way and the high driver in a two way. You really don't want to be sending all that energy to a high driver, even if it isn't responding audibly (to the unwanted low frequencies).
rajacat
  • Washington State
« Reply #91 on: 22 Jun 2016, 01:02 am »
Yeah, but wouldn't this be like two single drivers integrated into one speaker. Bass/midbass driver would be designed for, let's say 60hz > 650hz rolling off gradually. Treble driver 750hz >18000hz. Just run them free range. I don't understand how the voice coils would heat up in this design. No crossover parts whatsoever. Bi amp them.
Russell Dawkins
« Reply #92 on: 22 Jun 2016, 01:25 am »
Yeah, but wouldn't this be like two single drivers integrated into one system. Bass/midbass driver would be designed for, let's say 60hz > 650hz rolling off gradually. Treble driver 750hz >18000hz. Just run them free range. I don't understand how the voice coils would heat up in this design.
Considering the treble unit only, if it was being fed full bandwidth, but reproducing only from 750Hz up, where does that energy from 20Hz to 750Hz go? It's wasted as heat in the voice coil and contributing to too-early thermal compression due to the rising resistance in the voice coil due to that heat. Not such a big deal in a bass/mid driver, although the characteristic that would lead to a 650Hz rolloff are in conflict with what is needed for fast transient response times.
Then you have the myriad problems associated with low order crossovers, even without the crossovers, such as the need to be precisely aligned in the vertical axis of dispersion in order to hear the intended frequency response, due to both drivers being so active over the few octaves they have in common, etc.
The only current examples of successful designs like this involve a very well behaved widerange driver running free with a tweeter supplementing the highest octave or two only, but crossed over—except for the French (those French!) PHY   http://www.phy-hp.com/   which utilize a piezoelectric tweeter as an HF unit. Piezzos are naturally bandwidth limited by nature and *can* be used without any crossover—but even they can benefit:
http://www.frugal-phile.com/piezo-XO.html
rajacat
  • Washington State
« Reply #93 on: 22 Jun 2016, 01:41 am »
Ah I see. How about if you over engineer and have a voice coil that can handle the heat?
G Georgopoulos
« Reply #94 on: 22 Jun 2016, 01:48 am »
rajacat,what are you saying man  :lol:
DaveC113
  • ZenWaveAudio.com
« Reply #95 on: 22 Jun 2016, 02:08 am »
That's about what Louis at Omega is doing with the 1.5 way design, but the 2nd driver is crossed over at the baffle step using a single coil, so there is a crossover but just one component. The other driver is run full range.
JDUBS
« Reply #96 on: 22 Jun 2016, 02:12 am »
Sorry, my reference to the DCX may have confused things.  My DCX will be used solely to control the subs.  The only DAC in the signal path to my mains is my Auralic Vega.  I had been trying not sidetrack the thread's discussion of active speakers in general by detailing my personal system, but...
To start with, my music is stored on a NAS which connects to a Mac Mini via Ethernet.  On the Mac Mini, I run Roon for music browsing and HQPlayer to apply the driver EQ correction and upsample to the native sampling rate of my DAC.  The HQPlayer-processed digital output is fed by the Mac Mini to my DAC over USB.  The analog output of my DAC is then sent to my Bent TAP-X passive pre-amp, which has two simultaneously driven outputs.  One pre-amp output is sent to the active gain-stage equipped, analog, line-level crossover (a Pass XVR-1), then the Pass XA30.5 amps, and finally to my 2-way speakers.  When I get my subwoofers finished, the second output of the pre-amp will route to the DCX, which will then control the full array of subwoofers.
So yes, the DCX imposes an extra ADC/DAC, but only to the subwoofer signal path, not the mains.
A few misc notes...
  • The mains path is fully differential from end to end.  The subwoofer path is fully differential except for the DCX, which is impedance balanced, but not truly differential.
  • HQPlayer's unique polysinc reconstruction filters are viewed by many to be superior to those found in almost any DAC, thus the choice to upsample to the DAC's native DSD128 sampling rate on the Mac rather than rely on the DAC's reconstruction filter to do it.  (HQPlayer is also the only software or hardware that I know of that can apply EQ correction to a DSD audio stream.)
To clarify for the sake of multiple other posts, an active speaker system is one that has the cross-over implemented before the amplification stages, when the signal voltage is at line-level.  A passive speaker system has the crossover implemented after the amplification stages, when the signal voltage is at speaker-level.  The active/passive distinction does not depend on whether the line-level crossover is digital or analog, or whether the amplification is internal or external to the speaker.
Again, it's unfortunate that "active" is used in audio both to distinguish between powered vs. unpowered components (or more precisely the presence of a powered gain stage), and systems using line-level vs speaker-level crossovers.  For example, there are many "powered monitors" out there that are not "active" in the sense of having a line-level crossover.... they simply have a built-in amp that still feeds an internal speaker level crossover.
Hope that helps.
We now return to lusting after Josh's JBL M2s...  oh wait, I mean Andrew Jones's discussion of active speaker benefits!  :)
brj, oh yeah, no, totally get that.  My comment was really just a general one re: dsp across the whole frequency spectrum.  The dsp-effected dsd that the hqplayer guy(s) tout is definitely pretty impressive if possible.  I don't think the jriver guys think it is
Instead of using a line-level crossover at all why not just audiolense / acourate with a multi-channel dac?
-Jim
rajacat
  • Washington State
« Reply #97 on: 22 Jun 2016, 02:30 am »
Here's manufacturer of a woofer that found a way to reduce power compression.
TD15M Highlights: Power compression is also incredibly low due to the combination of shorting rings and the phase plug.  The Apollo Upgrade is available which further lowers distortion and increases the heat transfer away from the voice coil.
http://aespeakers.com/shop/td/td15m/
Lambda Motor with Full Copper Faraday Sleeve (FCFS) (Apollo Option available)
Extremely low and linear inductance
Ultra wide bandwidth for detailed midbass and midrange
Designed for live sound, high efficiency theater, and critical monitoring
Ideal UPGRADE for many vintage drivers (2226H, 416, 421, 5158G, etc)
Russell Dawkins
« Reply #98 on: 22 Jun 2016, 02:31 am »
Then you have a voice coil that is so heavy the HF performance will be lousy.
G Georgopoulos
« Reply #99 on: 22 Jun 2016, 02:37 am »
Russell,not to mention the impendance of the spk will be so low making it highly inefficient ,and the amp will heat up as hell
