Hi Vinnie, I may have missed this somewhere, but I didn't find the exact answer and was just wondering ...
The new DHT line stage acts in the "preamp" section correct and if so, does that mean I can still use my own amplification of choice? For example, I have a pair Omega Loudspeakers and a Decware amp that I like using with them quite a bit, but I really want a full function preamp with a remote, would this work in combination with the DHT fitted LIO?
Hi beowulf,
The upcoming LIO DHT PRE is in the linestage and will be offered as such (and more! see below), so you certainly can use your own amplification. I'm still working on all the details (in a week or two, I hope to have a webpage added for it, along with pricing/ pre-order information. I'm getting there - been so busy catching up after AXPONA!)
The way you can configure a LIO with the upcoming DHT PRE stage will be as follows (really just like with any LIO!):
SOURCES- LIO DSD/PCM dac with DHT output stage and external power supply (with our without volume control)
- LIO Phonostage with DHT output stage and external power supply (with or without volume control)
- Can easily be both in one unit (with or without volume control)
- LIO Remote Handset
These will be for those who want to only order it as a source component to feed their system (preamp / integrated)
PREAMPLIFIER- LIO INPUTS (3 sets of line-level inputs)
- LIO "NUDE RVC" (custom version of RVC with all Vishay Nude Z-Foil resistors, point-to-point wired onto the signal relays)
- LIO DHT PRE stage and external power supply
- LIO OUTPUTS (2 sets of variable pre-amp outputs, 1 fixed level)
- Could also contain LIO DSD/PCM DAC, PHONOSTAGE, and even HPA output stage modules
DHT INTEGRATED- LIO INPUTS (3 sets of inputs)
- LIO MOSFET AMP
- LIO OUTPUTS (2 sets of variable pre-amp outputs, 1 fixed level), as LIO INTEGRATED can also be used as a preamp (turn off
speaker output stage via front panel switch)
NOTE: At AXPONA2016, we had a LIO DHT INTEGRATED with DAC and PHONOSTAGE installed:
http://www.audiocircle.com/index.php?topic=142422.0FOR CURRENT LIO OWNERS- No matter your currenrt LIO configuration, the LIO DHT PRE can be added.
- Pricing and trade-in pricing to follow in the next week or two
WHEN???Realistically, this all won't be ready for shipping until the end of May / early June (based on where you are on the pre-order queue once we set that set up).
Top-panel and tube cover design has been finalized and I won't be seeing them in until late May.
Many other parts are here already and waiting to be assembled.
Tube covers: (black or silver) metal cylinder for each tube that the user can easily install over tubes only if desired. Comes
standard with any LIO DHT configuration above. It's a nice touch if you are worried about pets / children touching the glass tubes,
AND if you are using tubes that are sensitive to picking up hum in this configuration (e.g. 101D / 205D, others with high plate resistance)
More soon!
Vinnie
