0 Members and 1 Guest are viewing this topic. Read 7030 times.
Gentlebender,What is the enzyme you are using and where can I order some? I didn't see it in the first few pages of the thread on AK
Yeah I see the Formula 15 is touted as an all in one deal, but to never use it directly on the vinyl without being basically diluted using their "Pure water" mix bottle as well. I just went with the more direct enzyme formula to see what happens. I will just apply the enzyme cleaner with a brush giving it a light scrub all around on both sides, let it sit for a while on the spindle in the batch, then just drop it directly in the clean distilled water already in the ultrasonic machine tank, and let it do its thing. I assume it's going to be a little better, we will see.
The update:100% success! I tested a couple of tough surface noise albums by laying on the Enzyme cleaner from AI, letting them soak for about 15 minuets or so, and then dumping them directly into the ultrasonic cleaner while they were still pretty wet. I can't believe how dead silent these albums came out. It works. As long as there is no real damage I guess you can do more. Ultrasonic alone was not quiet enough to get a few of these at this level. But the combo of about 30 seconds scrubbing on some of the enzyme and letting it sit did in fact work beyond expectations in this case. Plus the bottle was about 18 or 19 bucks which should last me 3 to 5 years no problem with the occasional spot treatment needed on some albums. Not saying this will make every record perfect, but ones you know are right there this can make it happen it seems.
