0 Members and 1 Guest are viewing this topic. Read 7024 times.
If metal is left in an ultrasonic cleaner for a long period of time, it will dissolve. In my early days of drafting skool, we had an ultrasonic cleaner for the ink pen tips. Occasionally, someone would leave the tips in the cleaner over the weekend, and the tips would be gone or partially left.'ner
As a blanket statement, this cannot be true or the stainless vat itself would erode. I suspect that the missing parts were more dependent on the nature of an acidic solvent as opposed to the effects of cavitation- or someone simply removed them. For a metal to dissolve, it has to be soluble, which almost always means it has to ionize, which almost always means it has to lose electrons, which means something has to take the electrons (hence, an acid).
Wait, you are saying that metal parts "dissolved" in water???? Over a weekend??? Now, you understand that all metals that are used in pen parts (no Li, Na, Ca, - I'll even give you Mg since it can react with steam) don't react with water, are not soluble in water, are not affected by the polarity of water molecules, so the cavitation would have to be what broke the molecules apart, in which case the powder would have been deposited at the bottom of the vat. Pen nibs are Fe, Cr, Ni, w/ traces of V, W, Ir. Earlier ones were primarily gold because the inks were caustic. This stuff just doesn't disappear in water. Let's just politely say I doubt if ultrasonic cleaners damage vinyl. We have had this disagreement before about the possibility of damage, but this scenario is chemically so improbable/impossible...
It happened more then once. It has nothing to do with chemistry and everything to do with physics.
