0 Members and 1 Guest are viewing this topic. Read 22744 times.
Don't forget this one:http://www.welltemperedlab.net/welltemperedlab/products/ltdtonearm/
The 10 and 12 inch Jelco arms are on the heavy side in the 20g range. Both priced well below 1000 bux new. Silicone damping at the pivot if you need it. Removeable headshell for easy cartridge swapping. Performance reaches way beyond its price. Worth looking into.
Sunny,The 12" 750 is on my list, but I thought the effective mass was ~11 - 13g, although with cartridge it gets close to 20g? Also, by the time a headshell and wiring is added the price sneaks above $1k.
Wow.......that Pioneer is some hunka metal! Really built! If build quality translates into sound, I'd snatch that thing up!But who knows? The web seems thin on info.http://www.canuckaudiomart.com/details/649225775-pioneer-exclusive-tonearm-pa70-trio-x3/
...and the sparse information that does exist is seems to be poorly translated Japanese. I have an email into the seller.
I don't know what grunge buster is, but your mount needs to be rigid, and more mass is generally better. Lead is super at slowing vibrations - good idea. Lead + sand works too.
The removable headshell allows you to adjust the mass somewhat, and tune the sound. Many quality arms w/removable shell have 2 tiny screws behind the locking collet on the bottom of the armtube. Often these can be used to adjust azimuth. This is a feature people often don't know they have, but it depends on the arm. This is a good value w/adjustable azimuth on a 12g shell:http://www.lpgear.com/product/LPGZHEAD.html
The downside of removable shells - the boundary tends to reflect vibrations back to the cart instead of down the arm. The "perfect" shell for a particular cart/arm requires a bit of alchemy. Wood shells are good dampers. Some metal shells are light, 7g and up. Check these out:http://www.joynetmall.com/store/index.php?route=product/category&path=60_381&page=1The Ortofon LH8000 looks nice and check out the Yamamotos on page 2. Ebony is a great mix of rigidity and damping:http://www.joynetmall.com/store/index.php?route=product/product&path=60_381&product_id=1594
I think this is one of those opportunities to pick up something of extreme value, NOS. If this arm was being made today, it would be around $5K, no BS.The 7082 actually has a better reputation than the Pioneer, maybe because it's more well known. I think either one will knock your socks off with the Zero.neo
