0 Members and 1 Guest are viewing this topic. Read 10318 times.
This is the template used to cut out the base. The overall dimensions are 14-1/4" deep, 11-1/8" wide at the front and 12-3/4" wide in the back.Hope you can read everything on the picture. I didn't really have any dimensions at first, I just traced the outline of the Wedge baseon a sheet of plywood and started cutting pieces on the miter saw and screwing them down to the plywood until I liked the shape.The sides and the center point of the front are recessed about 1/4" in from the Wedge base. There is a 5" or 6" radius in front and the frontlegs come out at 30 degrees. The legs are 2-1/4" wide tapering to 1-1/4" at the end. I see one dimension I forgot is where the 30 degreeline intersects with the centerline. It is 10-1/2".
Damn, those are some nice looking speakers... I will have to think about something like those for me someday...
