0 Members and 1 Guest are viewing this topic. Read 62096 times.
[Deleted by maty]Maybe, the next ELAC Uni-Fi UB5 coaxial speakers. The problem is that you need to wait a while to know their frequency, phase, impedance graphs... and reviews.-> http://www.audiocircle.com/index.php?topic=140079.msg1515795#msg1515795
Didn't know about tapping them, thanks for sharing that bit of knowledge. I'll stick with the measurement mic though and give it a shot soon.
I just purchased the ELAC Uni-fi UB5 blemished (i.e. greenish tint on the mid-range driver) from Amazon for $399 and it is amazing!!I can't believe the sound quality for the $$
What stands out about them in particular
That dip and 1.3k followed by a rise to 2k seems like an extremely common pattern that I have seen in speakers.
They are nice sounding speakers for the price but not at the same level vs the LS50 imo. There's no getting around the fact the ELAC uses an inexpensive tweeter and good tweeters aren't cheap. Not that the ELAC tweeter sound bad, it's fine... probably very good for the price of the speaker but the LS50's concentric drivers are far better imo.
…Now for the down side. As soon as you try to really play music the speaker becomes a shout box. When turning them up past 92dB (measured near field) the speaker loses control, and starts sounding more like a PA system than HiFi audio.…I asked ELAC why the speaker shits the bed is such a unique way at 92dB, and did not get a response. My instinct here is that this limitation is because of driver design, maybe not enough magnet or copper on the midrange.
Speaker type: 3-way, bass reflexTweeter: 1 x 1-inch soft dome, concentrically mountedMidrange: 1 x 4-inch aluminum coneWoofer: 1 x 5.25-inch aluminum coneCrossover frequency: 270 / 2,700 HzFrequency response: 46 to 25,000 HzSensitivity: 85 dB at 2.83 v/1mRecommended amplifier power: 40 to 140 wpcPeak power handling: 140 wpcNominal impedance: 4 Ω; minimum 3.4 ΩBinding posts: 5-way customMagnetic shielding: NoCabinet finishes: Black brushed vinylAccessories included: Magnetic fabric grilleDimensions (WxHxD): 7.87″ x 12.75″ x 10.75″
