0 Members and 1 Guest are viewing this topic. Read 18947 times.
You could do it but you have to run in 2.1 mode. If you only want to run 2.0 then you have to turn EQ off. There is better option is using 2 channel preamp with HT bypass, imo.
In my opinion.... you can't do HT and 2 channel in one system.
I ran my modified squeezebox and any other two channel sources into my Dodd preamp. I played all two channel through the Dodd and a nice 2-channel amp. If desired, some of the 2-channel sources can also be run into the AVR. I used the AVR for movies and used the HT bypass for movies. I think it's too hard to build two different systems. You'd need two different rooms, and most people don't have that kind of real estate. I'd rather sink money into one room, and make it sound proof and acoustically correct, and get the system to serve two purposes. Otherwise, you'd have to sink money into two rooms.
You guys are making this waaaay to complicated. This is what I did:First off, ditch the AVR. Is it gone? Good, now we can build something that works and sounds good too.Get a nice 2 channel preamp and amp. Now you have the hard part done - an excellent sounding stereo.
For 2-channel, he'll still need a DAC and a transport. The OP wants to build an "audiophile grade" 2-channel system. To achieve that goal, he certainly can't use his DVD player as the source. With these four component purchases, he's back to building two separate systems.
Yep. Merging an audiophile two channel system with a home theater system is incompatible. My HT and 2-channel systems share front speakers, but that's it. I even use separate speaker cables and switch them out when watching a movie.
