0 Members and 1 Guest are viewing this topic. Read 18955 times.
If you really want a nice, acoustically good and sound proof room, it'll be thousands upon thousands of dollars. I spent several thousand just on room treatments (9 realtraps plus two substands, plus more that I can't think of right now). And would've liked to have more, plus maybe some diffusion. And that doesn't touch the actual building of the room, where I did many, many, many weekends of work myself, ran all the wires myself, etc. Having two rooms like that just isn't feasible unless you're quite wealthy and have a very, very large house.
I run preamps with HT Bypass (and separate two channel amps) in two separate systems. Works well.
If I want 2.1 Stereo, I can do that too, since my Candela has a 2nd set of outs, which I can run to my sub. I have a simple 2 way switch at the sub to select source from the Candela or the Receiver.Just need a high quality stereo pre with HT bypass and you're good to go - keeps the same main amps and speakers.Am I missing something?
I'm not sure I understand why some say one cannot integrate a quality 2 channel stereo into a HT. Just need a high quality stereo pre with HT bypass and you're good to go - keeps the same main amps and speakers.Am I missing something?
.............and then Tom comes in and make most of us feel inadequate. Awesome room Tom. I'm envious.
