0 Members and 1 Guest are viewing this topic. Read 8171 times.
I seriously doubt the issue has anything to do with your amp.
I think it has almost everything to do with the amplifier. It is a rare occasion that a big amplifier and inefficient speaker will ever sound good at low volume levels. Now you know why some of us use a low wattage, pure class A single ended amplifier with a more efficient speaker. We get the same great sound at all volume levels.
You need to energize that speaker and get it moving as mentioned. Idling along with low watts is not going to cut it. Kick it in its butt and make it sing. Doesn't have to be 90 db, but if you are like most of us in the 75 to 85 db range, then having some more power means you can handle the transients inherent in most music.
There is one other possible factor involved here. Back in the '30's at Bell Labs, Fletcher and Munson (google Fletcher/Munson Curve) demonstrated that at low volumes, human hearing is less sensitive to bass and high treble frequencies. That is why, in the 70's, many amp manufacturers added a "loudness contour" control (which you don't see very often these days) to their products. Basically, this circuit EQ'd the signal to boost the appropriate frequencies when listening at low volumes.
I think it has almost everything to do with the amplifier. It is a rare occasion that a big amplifier and inefficient speaker will ever sound good at low volume levels.....
