Let's See Your Transformers!
0 Members and 1 Guest are viewing this topic. Read 104732 times.
Re: Let's See Your Transformers!
« Reply #300 on: 16 Jun 2020, 06:18 am »
After my second attempt I found it:
https://en.royal-insulation.com/tercott-k
Its a brandname for kraft paper.
Interesting, this your link show TERCOTT® K
I have found TERCOTT® CB paper
https://www.toproyalisolantes.com.br/papeis-isolantes
TERCOTT® CB is a flexible insulator intended for use within the class B (130ºC), consisting of a dielectric paper support laminated with a polyester film. Indicated for isolation of electric motors (grooves and between phases), transformers.
Nominal thickness 0.18 / 0.20 / 0.25 / 0.30 / 0.35 mm
Width 980mm
Just found other types of Tercott:
Tercott PFP
Tercott FPF
Tercott FKF
Tercott Duplex
Tercott CB
Tercott C DRPB
Requested the PDF info, lets see if they will send.
« Last Edit: 16 Jun 2020, 08:10 am by FullRangeMan »
E55l2
« Reply #301 on: 17 Jun 2020, 08:09 pm »
« Last Edit: 7 Jun 2022, 05:59 am by E55l2 »
« Reply #302 on: 18 Jun 2020, 12:09 am »
Wow 0.05mm incredible thin lamination, this C core seems solid.
Dumb question: choke and interstage run in different positions but they are similar?
E55l2
« Reply #303 on: 18 Jun 2020, 05:51 am »
« Reply #304 on: 18 Jun 2020, 06:05 am »
In a choke there is only a primary winding , a interstage is as a normal transformer and has primary and secondary winding. Just as the small diagram what you can see on the photo i posted.
Hmm the chokes are inductors  :thumb:
This your C core doesnt seem to be formed into slices as usual in a EI, would it be formed with layers?
E55l2
« Reply #305 on: 18 Jun 2020, 10:46 am »
« Last Edit: 7 Jun 2022, 06:00 am by E55l2 »
« Reply #306 on: 19 Jun 2020, 07:02 am »
Toroids and C-cores (this 0,05 mm too) are all winded as a roll tape. The toroid is round, the c-core oval and later they cut the oval core and the you have 2 C’s.
They can look solid but if you look more closer you see the individual laminations.
Interesting, that is a great solution, congratulation for your new line of transformers. The Tercott seller send me only the Tercott CB tech PDF, the disruptive voltage range from 6 to 10kV according the Polyester tickness film.
Digi-G
« Reply #307 on: 19 Jun 2020, 02:22 pm »
Can we please refrain from calling them 'trannies'.  I cringe every time I read that.
E55l2
« Reply #308 on: 19 Jun 2020, 06:00 pm »
« Reply #309 on: 19 Jun 2020, 10:39 pm »
Seems a nice transformer, do you have any photo?
E55l2
« Reply #310 on: 20 Jun 2020, 12:56 pm »
« Last Edit: 7 Jun 2022, 06:01 am by E55l2 »
« Reply #311 on: 21 Jun 2020, 05:01 am »
Wow that is a demo show transformer :thumb:
What is the winding cover? seems pressed rubber
E55l2
« Reply #312 on: 21 Jun 2020, 06:18 pm »
« Reply #313 on: 21 Jun 2020, 06:33 pm »
To tell the truth I like the euphonic sound of tubes, it so romantic, vintage, beautiful....paradise.
E55l2
« Reply #314 on: 21 Jun 2020, 06:51 pm »
I like the more modern sound of tubes amplifiers: ultra clean, ultra smooth And dynamic, not the sound of an old ‘50 radio (which i like to but as a background )
« Reply #315 on: 21 Jun 2020, 10:06 pm »
I think tube amps could came with two OPTs, one small and musical other big and dynamic, it will be a success among audiophiles.
E55l2
« Reply #316 on: 22 Jun 2020, 11:56 am »
E55l2
« Reply #317 on: 22 Jun 2020, 08:43 pm »
« Last Edit: 7 Jun 2022, 07:50 am by E55l2 »
Docere
« Reply #318 on: 22 Jun 2020, 09:27 pm »
This size transformer is just what you need for a decent tube amplifier. Most transformers i see are to small and are not qualified for the job. Unless you like colored muddy sound ofcourse.
The “cover” is gaffer tape, just some extra protection, could be any tape.
I think we have similar likes.
Here is a link to the interstage article via the Wayback Machine: https://web.archive.org/web/20190720200318/https://www.ankaudiokits.com/agrove_interstage.html
I will read it in the next few days. Thanks!
« Last Edit: 23 Jun 2020, 06:48 am by Docere »
E55l2
« Reply #319 on: 23 Jun 2020, 02:49 pm »
