0 Members and 1 Guest are viewing this topic. Read 104758 times.
Lundahl transformer upgrade for Eleket TU8600R 300B SET.0609201205_HDR by drjlo2, on Flickr
https://www.lundahltransformers.com/wp-content/uploads/datasheets/2770B.PDFThis is the datasheet from LundahlFrom the datasheet i read the induction is 45H at 60mA with Ra=3200 Ohm (45H is way to much) Lundahl says B=0.9T at the static current of 60mA.This means that they need a lot of windings to get the 45H on such a small core and the airgap is just 0,14mmI doubt this works good* and if it works the saturation comes very soon. If you have a amplifier >50Hz this would probably be ok but i think lots of people like to have FULL range from 20Hz.* i am pretty sure it sucks
If they use a constant current source to balance the transformer it could work but my god what a total disaster that amp must be. Just save the tubes and the rest is garbage.
