Let's See Your Transformers!
0 Members and 1 Guest are viewing this topic. Read 105052 times.
Re: Let's See Your Transformers!
« Reply #180 on: 26 May 2016, 12:44 am »
« Reply #181 on: 26 May 2016, 12:44 am »
« Reply #182 on: 26 May 2016, 12:45 am »
J-Pak
« Reply #183 on: 3 Jun 2016, 01:41 pm »
I've been using Tribute MC step transformers for over a year. I've owned amorphous and mumetal Lundahl, S&B TX-103 copper, Cinemag, Peerless and these are without question the most transparent transformers I've ever heard. Very sweet midrange as well. A shame he won't winder for DIY'ers :(
E55l2
« Reply #184 on: 11 Jun 2016, 03:01 pm »
« Last Edit: 7 Jun 2022, 06:13 am by E55l2 »
« Reply #185 on: 11 Jun 2016, 03:59 pm »
These transformers are very easy to make, Tribute just uses a very nice core, nothing special else.
Btw You can find many people who waited 6- 12 month before Tribute delivered there transformers, not a recommondation worth i think.
Wow and I though 4 months was much for my Ogonovski.
What exactly is Nano cristaline?
Its amorphous?
It is similar to Finemet?
E55l2
« Reply #186 on: 11 Jun 2016, 04:30 pm »
« Reply #187 on: 11 Jun 2016, 04:36 pm »
Thanks for clarify, I fell less dumb now.
Seems Finemet is a brabd from Hitachi.
Do you mean say you work for Tribute for 20 years?
E55l2
« Reply #188 on: 11 Jun 2016, 08:07 pm »
« Reply #189 on: 12 Jun 2016, 11:19 am »
This is great, these are very nice cores to start a OPT.
Regards
E55l2
« Reply #190 on: 12 Jun 2016, 03:27 pm »
« Reply #191 on: 12 Jun 2016, 11:36 pm »
Thanks I will look.
Tube amps are basicaly power, choke and OPT transformers.
There is a best core for each these functions?
Wow he guy cut the transformer in half!
E55l2
« Reply #192 on: 13 Jun 2016, 09:13 am »
« Last Edit: 7 Jun 2022, 06:14 am by E55l2 »
« Reply #193 on: 13 Jun 2016, 03:44 pm »
Wow awful looks a guitar transformer.
E55l2
« Reply #194 on: 2 Jul 2016, 08:27 pm »
« Reply #195 on: 4 Jul 2016, 11:57 pm »
Well unfortunately there is many audio equips as these.
New2Audioguy2
« Reply #196 on: 28 Jul 2016, 07:10 pm »
What determines the quality of a transformer like that? Just the coil work or the inserts in the middle as well?
« Reply #197 on: 29 Jul 2016, 05:19 pm »
As everything in audio all small details in a transformer has an impact on the resulting sound, including insulating paper, electrostatic screen not to mention the winding quality:
Good:
BAD:
MothAudio
« Reply #198 on: 7 Feb 2017, 03:46 am »
Electra-Print BE5KB 3k OPT
« Reply #199 on: 11 Feb 2017, 06:19 am »
One point that I think is important is that over the decades, and with experiments designed to test non linear
parts and designs in my test audio system, auditioners have found that the more accurate the parts and design, the better synergy, the more satisfied they were with the system/musical reproduction.
Using non linear parts/components and attempting to compensate in the speakers and other components always produced less satisfaction than when the accurate parts/components were introduced and attempted to optimize. This makes sense since overall synergy of the accurate audio system is maximized and weakness/"faults" were minimized.
Thus the OPT must be designed for maximal flatness in frequency response, actually in tonal balance, just like any other part. We have already seen over the previous pages the problems with high frequency response and to a lessor degree to the low frequency response. Rectangular waveforms can be useful in exposing problems.
An OPT that is bass heavy/bass light or high heavy/lacking in highs will require compensation of the rest of the circuit in order to "compensate" as best as possible. However, as stated earlier, optimum satisfaction with auditioners occurred when all the parts and components were optimized for fewest "faults", thus the best synergy.
The only possible way to know for absolute sure if an OPT is optimal is to test the OPT in an optimally designed circuit. Easy to state, difficult and time consuming to accomplish.
Cheers
