0 Members and 1 Guest are viewing this topic. Read 49793 times.
My understanding is that the 1.5's don't use a crossover per se. Just an inductor on the bass driver which serves as low pass at 500Hz. The main driver runs full range and gets signal straight from amp as with the single driver speakers.My question about the design is in the balance of frequencies. I don't understand electronics enough to know what changes in the FR curve there might be. The second driver increases sensitivity substantially and reduces impedance to 4 ohm. That will alter the sound of the main driver compared to a single driver version. But does the second driver just augment everything below 500 or is the balance now shifted so that range, particularly 300 or so to 500 isn't too strong? (I'm think in terms of the ported box design, not the OB, but don't know if that's relevant)......Peter
And that's what requires an actual audition. There may be some theoretical problems with OB+box design running in overlapping frequencies on the same axis pole, but I am not very well versed in all that phase-refraction-frequency stuff. Tekton's solution was to put the second driver in phase at 90 degree angle behind the OB driver working in low-mid region, which was "sucking" lower frequency back wave from the OB driver, allowing higher dipole frequencies to disperse behind the baffle and directing lower frequencies out the front facing port. That design resulted in very wide and accurate soundstage with believable bass response from 4" driver. Louis' design puts full range into OB and "augments" lower frequencies with additional driver. If there is no crossover for the OB driver there may be some phase problems affecting low frequency response, especially with the port facing back and speaker closer to the back wall. Who knows, maybe I don't really know what I'm talking about
Hello ClefChef,I checked out your gallery and if the system you are currently running is the one with the Wright Monos and OB4.5s, my guess is it would be very sweet sounding indeed. Now all you'll have to do is try a set of Omega 1.5 Partial Open Backs so we can all know the differences.
There is a crossover, it's just a single inductor that rolls the driver off at 6 dB/oct from the xo point. Issues with interference depend on distance between the drivers and frequency, since they are crossed over low there won't be any issues in the overlap area. This is reasonably popular configuration to run, usually in 2.5 way instead of 1.5 way as slim tower speakers can't use large woofers so they use 2 of the same woofers, often with different crossover points. IMO, the "purity" and coherence single driver speakers offer isn't going to be taken away with this design. Happyrabbit owned both so you could check out his comparison too.
I think we are dealing with semantics around terms like crossover and low pass filter, etc. But saying the same thing.Thanks.....
Yes! Most people think of a collection of parts that make up a crossover or filter, but it's not that, it's just a single component, an inductor. It is a crossover and a low pass filter, the simplest one possible.
I hope the design is not proprietary and Omega could borrow some ideas.
What press I have read on the Tektons has been all positive, so I don't doubt it is (was) a good speaker, but to seriously compare the two, they need to go head to head...but then, why bother, the OB4.5 is discontinued.
Looking at the Tekton Website, it appears that the OB4.5 might be resurrected. It's says that there is a model 4.5 V2 that's presently in the design phase. Maybe sometime in the near future, we can get a relevant comparison.
Something I'm not sure I presented strongly enough, is these must be accompanied by a sub woofer. And the more you fiddle with your sub settings, the happier you'll be with rock. I had supplemented "regular" speakers with a sub in the past, but with just enough volume and crossover to fill in the lows that my speakers didn't cover. These need a much higher crossover point where the sub also interacts with the midrange. In my opinion it helps with the natural forwardness of this type speaker while rounding out the presentation.
... I sold my tap-x for a ecc99 based preamp from Elliott Studio Arts. Magnetic coupled in / out. I am lovin this pre with my 2a3 amp. I find myself listening to cd's I don't even like.Dwight
