0 Members and 1 Guest are viewing this topic. Read 49358 times.
Ha, he's making fun of people asking for reviews jelly = jealous. I've had bipoles in the past and 3' from the back wall is a minimum with more being better. I don't think 5.5' is a requirement but probably is close to optimal.
DaveC113 lolCanada BOB - 2A3 SE with EML Tubes. I haven't listened to my SS Class A amp yet. new update to the layout - 3' from the left wall and 4' from the back wall. Speakers are 7' apart and listening position is roughly 7' - 8' ( center line from the speaker plane )opnly bafld- Thanks for the insight Dwight
What amp are you currently running them with? Please explain "Super Jelly". Louis' speakers have always reminded me of things that are very solid, like concrete.
Here they are Dwight
Hey BradMy point is that Louis would add more credibility to his speaker company if he would post measurements of the finished speakers and/or the driver measurements using industry standards similar to what Eminence does:Multiple units exceed published rating evaluated under EIA 426A noise source and test standard while in a free-air, non-temperature controlled environment.The average output across the usable frequency range when applying 1W/1M into the nominal impedance. Ie: 2.83V/8ohms, 4V/16ohms.Eminence response curves are measured under the following conditions: All speakers are tested at 1w/1m using a variety of test set-ups for the appropriate impedance | LMS using 0.25” supplied microphone (softwarecalibrated) mounted 1m from wall/baffle | 2ft. X 2ft. baffle is built into the wall with the speaker mounted flush against a steel ring for minimum diffraction | Hafler P1500 Trans-Nova amplifier | 2700 cu.ft. chamber withfiberglass on all six surfaces (three with custom-made wedges).The only measurements I've seen on his webpage was for the DIY 7F and 7A drivers, no longer available.I don't get the whole "proprietary" mystique that some manufacturers use. What are you trying to hide after all. More transparency would be welcome!Regarding where they are made, I'm almost 100% sure it is made in the USA. The 7A driver that I had didn't show the manufacture country of origin. Whats the big secret? Who makes it? It would show credibility if we knew whether it was Mepco, Eminence, etc. If its made in the USA then exploit that with transparency and get ABC news Diane Sawyer to do a special news piece on it like they have been doing for they past year or so! You can do this AND maintain your proprietary and intellectual rights IMO.Anyway I'm done with this and won't post any more about it. Sorry if I pissed everybody off.gab
HappyRabbit, we need a report on the Outlaw 1.5 Please!
