0 Members and 1 Guest are viewing this topic. Read 4910 times.
If you're in Colorado you are welcome to stop by.
Spoke with Louis. My best guess is that the Super 7 Alnico XRS is going to me the one for my space. Anyone have these? I would love to know how you have them set up and what you are driving them with.
That's what I'm running. Check my thread "Just saying hi => Omega questions => Super 7 XRS on the way! => Now Here!!" for way too much info, my experiences etc. Currently running with single ended pentode 5wpc Dennis Had Inspire amp with 6V6 power tubes.
Hi pstrisik.I was wondering how come a 6V6 pentode connected tube can sound better (According to what you wrote) than a EL34 triode connected ? ? ?The EL34 as the reputation of the best sounding triode connected tube.Guy 13
Guy...... The EL34 is a pentode also, not a triode. So no triode mode. Dennis is currently a strong believer in designing single ended pentode amps that run Pentodes "the way they were designed to be run". I'm new to both tubes, so I don't have much preconception. I will go back to listen with the EL34 (and the KT150's) again, no doubt. The 6V6's just hit me hard the none of the other tubes did, so I'm drawn to listen to them for a while. But all this audio perception is very fluid. So I will likely contradict myself in short order! ...........Peter
Decware also have a EL34 Triode amp (SE34).
Thanks FULLRANGEMAN.I forgot about that one.Now that I think about it, are you sure that the Decware with the EL34 is connected in triode mode ?Guy 13
Yes, Decware sign it with the ''Hazen Grid Mod'' (triode mode for 6W).http://www.decware.com/newsite/SE34I.htm
OK thread jackers…
