0 Members and 1 Guest are viewing this topic. Read 41195 times.
I just (today) received the same transformer you have. The wiring is as follows: the two red wires that are alone are 120V primary input. On the secondary side (5 wires), the two thin red are 150V output, and the thin black wire between these two red is grd. . The thicker black wires are the 6.3V outputs.Mine is playing right now for the first time, driving an un-modded blue board. It's my first foray into valves since I was a pup
Hey, Wired for Sound, I have gone through the same thing you have. I ordered the 6N3 preamp from aliexpress, and it arrived with a 240 volt transformer. Never again! I ordered a 110 transformer from Ebay and the picture was the same as Poultrygeist's, with blue wires. It arrived with the same colored wires, red and black, as the one you have pictured here. If you figure out how to wire this damn thing up, please post a diagram of how you did it because I am over two months out waiting to hear my beautiful sounding preamp. Thanks! Lloyd Bruney
Hey Lacro, thanks! I would have to buy a meter otherwise. Come to think of it, I may have to get one if I want to deeper into DIY.BTW, how do you like the sound? Did the 6N3 tamed the highs of the blue board? I am hoping the preamp will add a tube sound to 3116.
All that said, I'm still building three of the little cheap and cheerful TPA3116 amps and plan to combine at least one of them with a 3-tube 6N3 preamp. I love to build things, I'm always on the lookout for a bargain (as you can probably tell) and I also like the small form factor and power efficient design of these little Class D chip amps. Plus, after all the glowing reviews, I just have to hear one for myself!
Thanks for the heads-up on the speakers. I ordered a pair through Amazon and was very dissapointed that they sounded nothing like the great reviews. I just sent an email to Parts Express customer service.
Nice cheap and cheerful set-up. Pieces like you found don't show up at my local Goodwill type stores One item in your photo is quite cheerful, but I don't think it was so cheap...It's your "sweet" looking chair. Would you tell me more about it please? A pair of those would be nice in my Man Cave
Thanks as well. I contacted PE yesterday and was informed that the defective batch was sold between September of 2012 and June of 2013. I'll have to see if I can borrow them from my nephew for whom they were purchased. I never did any real listening to them, just plugged them in to an old receiver to make sure they worked then sent them off. I know I've read some contrarian views as to the sound quality, so it would be interesting to give them a run through myself.
That's a great price on the Pioneer's. I'd be interested in your opinion as to which speakers you prefer. I like the fact that the Daytons are sealed while the Pioneers are rear ported which makes placement a challenge. Haven't stuffed a sock in the Pioneer's ports yet but I may.
