0 Members and 1 Guest are viewing this topic. Read 41189 times.
This is like my 3 tube 6N3 preamp shown earlier and I know it sounds good. http://www.ebay.com/itm/w-Tracking-No-Buffer-6N3-x2-6Z4-Tube-Preamp-AMP-220V-110V-Transformer-G047-/261009955502?pt=LH_DefaultDomain_0&hash=item3cc567daae
Hey Wind you're looking good. And just like you I'm a little obsessed with the TPA's. From left to right the TPA3110 power amp, the 6n3 preamp, and the TPA3116 integrated amp. And the blue/black board is on order.
So tell me what's out there in vintage systems for $100 that's better.
There are really an infinite number of possible combinations, but like your $5 PS1, they require a little scounging around at the local thrift stores.Here's my "best" under $100 system from a year ago:This morning, I was playing around with several of the bits and pieces I've acquired at my local Goodwill over the past 5 months, trying different combinations of receivers and speakers. I thought I'd try to come up with the best sounding, most bang for the buck system I could assemble with a total cost of less than $100.Here's what I came up with:Receiver: NAD 7250PE - $19.99CD Player: Sony DVP-S7000 - $9.99Main Speakers: Mitsubishi Diatone DS-73D - $29.99Subwoofer: Boston Acoustics PV700 - $29.99Speaker Stands: Optimus SS-10 15" - $7.99Total - $97.95I've been listening to this system all day, both FM and CDs and I'm pleased to report I got my money's worth. All these items were purchased at the same local Goodwill within a period spanning about 4 months.Since that time, I've also scored a better subwoofer for less money (Definitive Technology ProSub 800 for $9.99), a couple of SACD players (Marantz DV6600 for $14.99 and Sony DVP-NS3100ES for $29.99). I've also added a Magnum Dynalab FT-101A FM tuner for $39.99 and have picked up several additional sets of cheap and cheerful speakers (Dynaco A25 for $29.99, Monitor Audio Bronze B1 for $9.99, Pioneer SP-BS22-LR for $79.99).So, I could swap the subs and replace the CD player with either of the SACD players and keep the total under $100. I am currently using the Marantz DV6600 in that system downstairs and the Sony DVP-NS-3100ES, along with the Magnum Dynalab tuner, the Pioneer SP-BS22-LR speakers and the Definitive Technology subwoofer in my master bedroom system. But, that's my "expensive system" that also includes an NAD 3150 integrated amp ($50.00), Salamander rack ($24.99), a Panamax M5300EX power conditioner ($29.99) and a BIC Beam Box FM10 ($40.00) antenna. Counting the speaker stands ($9.99), I've got nearly $315 tied up in that system, but that includes multiple sources, an antenna, a power conditioner and the furniture to hold it all.Of course, these were all unique, one-time purchases, but I've had enough of these unique purchases to know there are more out there.All that said, I'm still building three of the little cheap and cheerful TPA3116 amps and plan to combine at least one of them with a 3-tube 6N3 preamp. I love to build things, I'm always on the lookout for a bargain (as you can probably tell) and I also like the small form factor and power efficient design of these little Class D chip amps. Plus, after all the glowing reviews, I just have to hear one for myself!
Blue #1 to port #5Blue #2 to port #4Blue #3 to port #3Black #4 to port #2 GNDBlue #5 to port #1This is a wiring chart for the 6N3 ( four dark blue wires, one black ground wire and two red wires for power cord to outlet ). Communication with Chinese ebay sellers is not the best and if the transformer has different color wires or more than 7 then this chart may not be of much help.
Can't you just power the primary, and measure the outputs of the secondaries with a DMM?
Received package of the 6N3 preamp but minus the board--separate mailing package? Return address of sender is in Singapore. And I thought sender is from Hongkong or mainland China.The transformer I received has 5 wires like Poultrygeist, but different colors. Wires 4 & 5 are thicker gauge (both black) than 1,2, & 3. I imagine the color does not matter, as long as I follow the order of wires from Poulrtygeist's diagram, it will be correct. Wires 4 & 5 will connect to 4 & 5 of preamp board. What do you think Poultrygeist? Thanks!
