0 Members and 1 Guest are viewing this topic. Read 11832 times.
[/img]
Thanks,The fun continues. Progress is a little slow since I don't have that much time after work. Jay, I only wish that I had Ed's woodworking skills. My thought is, if I don't like my base, I can always go back to it at some later time point.Last night I started on the input wiring. I decided to change the supplied shielded wire to a Mogami 2534 (quad cable). This makes it a little more complicated since 2 cables are blue and 2 are clear coated (out of the 4). So, I used an ohm-meter to mark the wires on each end. The Mogami wire has a beautiful copper shield.So this is my #3 input connected:
Please don't forget to tell me what make - model of speaker you will use with your Stereomour.Guy 13
Guy, I am using Duke's AudioKinesis Jazz
