0 Members and 1 Guest are viewing this topic. Read 38459 times.
The noise floor of my tube amp with shorting plugs is quiet a bit quieter than running DAC in
I live in Middle East
WOW, you really did make a big move.
If I switch to USB on the DAC, a relay opens and the noise comes through. If on analog inputs of DAC, the noise goes away.
Also, regarding tube amp noise. I meant with shorting plugs the tube amp noise floor is revealed, correct? If so, when DAC connected, it's louder noise floor. Meaning the tub amp is "quieter" than the DAC?
"Another rather unique feature of our output transformers is that they float. They have no reference to ground. This is difficult to do in all but the most stable amplifier circuits."
