0 Members and 1 Guest are viewing this topic. Read 38467 times.
Have you considered a heavy duty extension cord to a completely different circuit for the whole system, both with the existing stereo circuit breaker on and off?
My guess is that it's too much Direct Current for the P3 to fully block.
We opened the panel, electrician and I, and I took pictures. When I measured the wiring coming out of wall for dishwasher it found what seemed to be 2 hot wires and a ground. One of these hot wires goes to chassis. Dishwasher says 120V (of course I can find no info online about the model!):Today, I put a cheater plug on the amp for testing only, hooked it up to an AC regenerator, and turned on the dishwasher.A loud buzz comes out of the speakers when dishwasher is running. At this time, I measured 20V AC across chassis of DAC to + Rachel binding post, 30V AC across AC Regenerator chassis to + Rachel binding post, and 3v from chassis of Rachel to + Rachel binding post. Trying to measure DC just kept rising.Also , the noise filter just mentioned appears to only filter noise above 80kHz, and this buzz is very audible.
I pulled out the dishwasher, and the conduit wiring comes in wrapped in white sheath. It has (3) wires: green, black, and yellow.These are wired: black/brown (HOT) | white/blue (7-9v) | yellow/chassis (7-9v)There is also an internal green ground wire coming down out of dishwasher harness that goes to chassis.I have the breaker off, and curious why the yellow goes to chassis. Doesn't seem right based on what I'm reading but who knows how it is really wired at breaker.Proceeding with caution.
In your first post, you said when you disconnected the source cables from the power amp, did you disconnect them at the power amp end or the preamp end? If you disconnected them at the preamp end I would expect the hum you reported. If you disconnected the source cables at the power amp end, so only the power amp was connected to the speakers, I would not expect hum from the speakers unless the power amp is defective.If the amp is connected to the speakers only, with no other connections, there cannot be any ground loop hum connections, unless you are using active powered speakers that each also have AC power connections.Which is the case here?Frank Van Alstine
doctorcilantro,An interesting thread. I have been following it for a while. Your above pictures peaked my interest today. Could you take a picture of the top part of the panel? One of the pictures showing the bottom of the panel shows a close up of the feeder, left hand side, that is the feed for the panel. I see 4 insulated conductors exiting the feeder conduit. Is the panel 3 phase 4 wire? 3 hot conductors and a neutral conductor?What Kind of building structure do you live in? Jim
It has (3) wires: green, black, and yellow. The yellow wire could be a discolored white wire. These are wired: black/brown (HOT) .. OK.white/blue | yellow/chassis .. Not OK.The white/blue | yellow/ wires should not be bonded, connected, to the chassis of the appliance. In the USA that is a NEC code violation. The Neutral and equipment grounding conductor shall be connected together at the main service equipment and at NO point thereafter.There is also an internal green ground wire coming down out of dishwasher harness that goes to chassis.That is where the green color wire, (the equipment grounding conductor), of the branch circuit feed should be connected to.With the neutral conductor and the equipment grounding wire connected together by the common chassis connection the equipment grounding conductor will carry neutral load current back to the electrical panel whenever the dishwasher is being used. The branch circuit neutral conductor should only be connected to the white/blue of the dishwasher. Break the connection to the chassis.Another neutral current path I see is if the dishwasher water feed is connected by copper tubing to a metallic water system. I see all kinds of neutral current ground paths.And if the hot water line to the dishwasher is not metallic..... If for any reason the branch circuit neutral conductor and equipment grounding conductor connection were broken back to the electrical panel and the dishwasher was turned on the chassis of the appliance would be HOT.Hot branch circuit conductor connected to black/brown lead of appliance >> through appliance connected load >> out white/blue appliance lead >> to connection to chassis. HOT 120V chassis with reference to ground.Jim
